Just bought 88 Si w/modified B16A
Old Aug 5, 2004 | 12:50 PM
Reelizmpro's Avatar
Default Just bought 88 Si w/modified B16A
Just picked up an 88 Si w/modified B16A (CTR cams, DC headers, CAI, Mugen Ecu, AEM AFPR) and the car is pretty fast. I picked it up cuz i needed a daily driver and have always liked the CRX. I have a few questions though:
1. I need speakers and plan on going 6.5 separates in front and 6x9 in the rear. Any thoughts?
2. My "check engine" light stays on, what are common causes?
3. How many miles per tank do those with B16 swaps (preferably 88's) get? I got around 150 miles on 8Gallons. I think the gas gauge is pretty inaccurate though. I understand the tank capacity is around 12 Gal, correct? Thanks.
Old Aug 5, 2004 | 12:59 PM
EL Vap133's Avatar
Default Re: Just bought 88 Si w/modified B16A (Reelizmpro)
I don't think you can fit 6x9 back there without modifying some stuff.
Also, do you know how to check for codes?
Old Aug 5, 2004 | 01:02 PM
Reelizmpro's Avatar
Default Re: Just bought 88 Si w/modified B16A (EL Vap133)
Hey I emailed you about your seats...small world. Anyway, no I don't know how to check for codes.
Old Aug 5, 2004 | 01:05 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reelizmpro &raquo;</TD></TR><TR><TD CLASS="quote">Hey I emailed you about your seats...small world. Anyway, no I don't know how to check for codes. </TD></TR></TABLE>
When did you email me?
Well you need to locate your ECU and count how many short and long blinks it throws.
For example, long blink=10 , each short blink is 1. If you get 2 long blinks followed by 2 short blinks, then you got code 22.
Old Aug 5, 2004 | 01:08 PM
b16_madman's Avatar
If it's still pre-obd then you should be able to lift up the passenger side carpet where your feet would rest etc. and look for a led that blinks when the car is on. I don't have links and stuff that tell you how to do this exactly, and I'm quite frankly not feelin like explainin it step by step...but with some searchin you can figgure it out, not too hard.
Sounds like you got a sweet deal on a DD.
Old Aug 5, 2004 | 01:09 PM
Reelizmpro's Avatar
A few days ago when they were on Ebay but you said they don't fit 88's without slight modification. Anyway, my seats aren't a priority at the moment so I may have to pass on them. Just trying to get this car in shape first.
Old Aug 5, 2004 | 01:18 PM
Reelizmpro's Avatar
Default Re: Just bought 88 Si w/modified B16A (B16_madman)
Just pulled up the passenger carpet and there's a large metal plate with 4 bolts covering something. Could this be the ECU? Does it automatically flash codes?
BTW, the car has no cat and runs on the rich side.
Old Aug 5, 2004 | 01:21 PM
bambam's Avatar
there should be a little light in the middle of it that will be blinking...
Old Aug 5, 2004 | 01:45 PM
Reelizmpro's Avatar
Default Re: (bambam)
Okay, does it blink automatically or do I have to do something first? short some terminals together?
Old Aug 5, 2004 | 02:17 PM
SuperSteve737's Avatar
1) turn your key to the "ON" position
2) count the blinks
3) report back to us
Old Aug 5, 2004 | 02:19 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reelizmpro &raquo;</TD></TR><TR><TD CLASS="quote">A few days ago when they were on Ebay but you said they don't fit 88's without slight modification. Anyway, my seats aren't a priority at the moment so I may have to pass on them. Just trying to get this car in shape first. </TD></TR></TABLE>
Ohhhh, hahaha, that was you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reelizmpro &raquo;</TD></TR><TR><TD CLASS="quote">Okay, does it blink automatically or do I have to do something first? short some terminals together? </TD></TR></TABLE>
Turn the car on, and just look at the ECU, it should start to blink. Now if it doesn't blink, then just turn the car off, disconnect the negative terminal to your car battery for about 1 minute, re-connect it and cracnk the car up. Wait a while and see if the Check Engine Light (CEL) turns on again.
Old Aug 5, 2004 | 02:31 PM
Reelizmpro's Avatar
Ahhhh I see what the problem is. The ECU is mounted upside down or something because the LED was blocked by the metal plate. It flashes 15? or 25. it has a long flash...(long pause) shorter flash - 5 real short flashes.
Old Aug 5, 2004 | 02:39 PM
EL Vap133's Avatar
Hmmmm, that sounds odd. It's either a long blink, or a few short blinks.
Old Aug 5, 2004 | 02:48 PM
kid-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">I don't think you can fit 6x9 back there without modifying some stuff.
I have seen it done, it requires a little trimming.
Old Aug 5, 2004 | 02:52 PM
EL Vap133's Avatar
Default Re: Just bought 88 Si w/modified B16A (kid-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">
I have seen it done, it requires a little trimming.</TD></TR></TABLE>
Notice I said "without modifying".....
Old Aug 5, 2004 | 03:12 PM
Reelizmpro's Avatar
Well, could it be 2 separate codes? Perhaps 10 and 15? that or it's flashing fault code 25.
19crx93
Jul 30, 2011 09:25 AM
jonezyboy6
Jan 24, 2008 04:53 AM
Firestarter
Jan 15, 2006 03:13 PM
jsteezy1290
May 18, 2004 12:33 PM
