idle drops bad when car is cold
Old Aug 5, 2004 | 12:21 PM
out_of_order's Avatar
Default idle drops bad when car is cold
soo about a month and a half ago i replaced my gasket for my intake manifold....ever since then when i warm my car up the idle drops to 200? or alittle above the 2nd line on the rpm....but when the car idle will go up to 900-1000 after about 5 min of warming up,and sometimes the car starts up it just dies out and would take about 8-13 cranks for it to start up again....none of this use to happen before i changed the gasket...BEFORE when i start the car it use to idle at 2000rpm and work its way down......anyone??
Old Aug 5, 2004 | 12:28 PM
crx_88_si's Avatar
check your coolant level and burp/bleed it of all bubbles.
duballstar
Aug 8, 2012 09:54 AM
BigDaddyRich
Jan 11, 2012 08:11 AM
RedR
Aug 4, 2008 04:38 PM
