left caster > right caster
Old Aug 5, 2004 | 09:52 AM
2Slow2Content's Avatar
Default left caster > right caster
I just got an alignment done this morning. I asked for a print-out of the alignment settings and noticed that there's a 0.6 degree difference between my right and left caster. Here's the specs (all in degrees):
Front: (L / R)
Caster: 1.8 / 1.2
Camber: -0.6 / -1.0
Toe: -0.05 / -0.05
Rear: (L / R)
Camber: -2.2 / -2.2
Toe: 0.00 / 0.00
Should there be that much difference between the two caster settings? From reading this: http://www.tirerack.com/tires/...n.jsp it sounds like it could be cross-caster to adjust for the crown in the road... but then shouldn't the right caster be higher than the left? I'm just worried that maybe something's bent in the suspension.
Do any of the alignment experts out there think this is normal?
Oh yeah, this is on a '99 Civic Si/Ex (Si in Canada, Ex in the US) with Eibach Pro-kits on Koni Yellows.
stevanrk
25
Oct 1, 2008 09:10 AM
b16a4
Suspension & Brakes
Aug 31, 2007 10:21 AM
rodvang
11
Jan 18, 2006 08:10 PM
pos99
Mar 24, 2003 06:57 AM
