Running Rich
Old Aug 5, 2004 | 08:21 AM
95_SOHC's Avatar
Default Running Rich
My 95ex is running really rich, it isnt oil its definitly gas what should I do?
Old Aug 5, 2004 | 11:04 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: Running Rich (95_SOHC)
how do you know it's running rich? need more info as to what you have on the car and what made you come to that conclusion.
Old Aug 5, 2004 | 01:12 PM
95_SOHC's Avatar
Default Re: Running Rich (vtecb20coupe)
The car is painted white and there is black smoke all over the back of my kit where my exhaust leads out. I pulled the spark plugs and they are fine no oil, no leaks from my head gasket or valve cover so thats why I believe its gas. I don't know if my air to fuel ratio is off, or if I have a bad sensor. Any ideas? What should I check? There is NO check engine light on either.
Old Aug 6, 2004 | 07:44 AM
B A N N E D
it could be so many things. have you at least pulled the plugs to see their condition?
Old Aug 6, 2004 | 09:36 AM
95_SOHC's Avatar
I checked the plugs they are fine there is no oil on them, and they are burning fine. It is a dark black smoke you don't see it in the air it just sticks to my bumper. If I start or accelerate I NEVER see any smoke come out. I wonder if my air to fuel ratio is off or if its a bad sensor?
Another thing I cant grab second gear if I try to chirp it, but my clutch feels fine could it be my clutch master cylinder?
jd-em
Dec 6, 2007 12:57 PM
importfanatic17
Jan 2, 2007 04:32 PM
sooo_slow
Mar 7, 2005 07:07 AM
RallySportCivic
Mar 31, 2003 07:36 PM
RuthlessEF-9
Dec 7, 2002 04:29 PM
