d16z6 strait piping......
Old Aug 5, 2004 | 07:23 AM
jdmCivic925's Avatar
Default d16z6 strait piping......
aye i was thinking of puttting strait pipiing on my d16z6 would it do the difference the performance???....2/4 piping......
Old Aug 5, 2004 | 07:39 AM
realblag's Avatar
Default Re: d16z6 strait piping...... (delsolb18c1)
It will move your powerband up real high and make it loud as hell, but removing restriction on the exhaust will help as long as you don't loose you exhaust pulse( too big piping)
Old Aug 5, 2004 | 07:52 AM
Filthy Focker!'s Avatar
Default Re: d16z6 strait piping...... (realblag)
Agreed. Straight pipes are not for city driving at all. YOu car will be sluggish until you hit around 4000 rpms then it would open up pretty good. I say a good 5 to 10 hp. Also, since no back pressure is created, you will be going through valves every 10000 miles.
fs
Old Aug 5, 2004 | 08:01 AM
Deemeetree's Avatar
Electrician
Yes, it will be better at higher RPMs. Your powerband down low will get hurt though.
Deemeetree's Avatar
Electrician
Default Re: d16z6 strait piping...... (filthy_shovel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel &raquo;</TD></TR><TR><TD CLASS="quote">Agreed. Straight pipes are not for city driving at all. YOu car will be sluggish until you hit around 4000 rpms then it would open up pretty good. I say a good 5 to 10 hp. Also, since no back pressure is created, you will be going through valves every 10000 miles.
fs</TD></TR></TABLE>
Is this true? With a straight pipe, you can damage your valves every 10,000 miles? Seems a bit extreme, no?
Old Aug 5, 2004 | 08:36 AM
Default Re: d16z6 strait piping...... (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">
Is this true? With a straight pipe, you can damage your valves every 10,000 miles? Seems a bit extreme, no?</TD></TR></TABLE>
Dimi, i can only provide my experience. I run a harley shovelhead with straight pipes. And every winter, i have to tear down the heads and lap the valves since the valves and seats become pitted by the lack of backpressure.
If i don't do that, well the valves will start to let oil pass by them and then i start burning oil.... Was 10000 miles exagerated? Maybe someone here runs this and can confirm...
fs
Old Aug 5, 2004 | 08:45 AM
Deemeetree's Avatar
Electrician
Well if it's true, then it's true. But I know there's a bunch of people on H-T who run straight pipe and I still haven't seen a "Don't run a Straight Pipe, it f*cks your Valves" thread yet.
Old Aug 5, 2004 | 01:59 PM
what if i get catback with it???
Old Aug 5, 2004 | 02:04 PM
the piping is like 2 1/4 inc.....and hi flow catback....will the cat back will help little bit
Old Aug 6, 2004 | 11:32 PM
al3e's Avatar
Default Re: (delsolb18c1)
just get the cat and ull be find man
team sedition
9INE 2WO 5IVE
redlinexd
Oct 22, 2008 09:42 PM
xmb63
Jul 6, 2006 08:13 AM
big-cat
May 7, 2006 12:19 PM
jdmCivic925
Aug 5, 2004 11:06 AM
rebohn
Jan 2, 2004 01:05 PM
