reuse a metalic head gasket:possible or not?
Old Aug 5, 2004 | 03:53 AM
Jobi Joba's Avatar
Default reuse a metalic head gasket:possible or not?
I removed the head of my car (errr...it's a Nissan,but I post here as I know there are plenty of men whith a good knowledge on this board) after having only covered 12km since the rebuild cause I had a problem on the bottom end.Now I gotta fit the head back.
My Tomei head gasket still looks fine and I wonder if I can re-use it or if I should fit a new one...
(I know a std head gasket can't be used twice,but as the Tomei is a reinforced metallic one,I really wonder if it's possible or not...)
Don't tell me that a HG can't be used twice because everybody say so...I won't reuse a std HG,but a metalic one SEEMS kind of reusable...
Thx for help m8.
Old Aug 5, 2004 | 07:11 AM
hondaguyef's Avatar
Default Re: reuse a metalic head gasket:possible or not? (Jobi Joba)
I would never reuse any head gasket regardless of the make. Just my 2 cents though.
Old Aug 5, 2004 | 08:19 AM
Ekasey's Avatar
Default Re: reuse a metalic head gasket:possible or not? (hondaguyef)
not worth pulling the head off again
Old Aug 5, 2004 | 10:00 AM
turbohondask's Avatar
Default Re: reuse a metalic head gasket:possible or not? (eLusive ek4)
copper hg can be reused 6 times , but i think it need to be heated and annealed or something like that.
and the hks/blitz can be reused 3 times as advertised I dont know about the Tomei, but check with AEBS in San Diego( Tomei distribtor).
Personally, I would use it if was said it was resuseble.
Old Aug 5, 2004 | 01:36 PM
Jobi Joba's Avatar
Default Re: reuse a metalic head gasket:possible or not? (turbohondask)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohondask &raquo;</TD></TR><TR><TD CLASS="quote">and the hks/blitz can be reused 3 times as advertised I dont know about the Tomei, but check with AEBS in San Diego( Tomei distribtor).
Personally, I would use it if was said it was resuseble. </TD></TR></TABLE>
Thx,I gonna try to find out if Tomei claims their HG are reusable or not.
Old Aug 5, 2004 | 05:28 PM
PodRacerSi's Avatar
I know people that have re-used them. I never have myself, but they have never had a problem with that.
Old Aug 6, 2004 | 07:45 PM
Default Re: reuse a metalic head gasket:possible or not? (PodRacerSi)
i reused a stock gasket used for 30k, just sprayed copper seal on it and it was good to go. But that was for a motor that needed to be done and it was 10 at night.
if you Reuse check if it looks good with no dent or the rings around the clyinder is nnot all cracked
Old Aug 7, 2004 | 05:16 AM
hondaguyef's Avatar
"reusing a headgasket is like reusing a condom!" Bell Tran
Vtec04
Engine Machining & Assembly
11
Oct 31, 2017 09:26 AM
DC2SIR-G
Oct 17, 2005 01:54 PM
Nikolai
Nov 14, 2002 12:34 PM
filetofit
Aug 13, 2002 08:49 PM
