Redline Synthetic ATF?
Old Aug 5, 2004 | 12:03 AM
accordinglyevil's Avatar
Default Redline Synthetic ATF?
I just bought some and after reading on the website it state that it is "GM Dexron II, Ford Mercon, and Mercedes Benz Automatic Transmission Fluid and is suitable for GM, late model Ford, or any vehicle which recommends Dexron IID or Dexron IIE or Mercon for refill. " My concern is that my Honda Owner Manual state that i should used Dexron III. Should I switch back to Dexron III or could I use the Redline ATF????
Old Aug 5, 2004 | 02:21 AM
bill-71SS's Avatar
Default Re: Redline Synthetic ATF? (accordinglyevil)
nothing but honda fluid in your trans.
Old Aug 5, 2004 | 02:26 AM
Robot Sonic's Avatar
Default Re: Redline Synthetic ATF? (bill-71SS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bill-71SS &raquo;</TD></TR><TR><TD CLASS="quote">nothing but honda fluid in your trans.</TD></TR></TABLE>
i will have to agree on that point, even my mechanic, he suggests nothing but their fluid, for some reason, its best engineered for their cars, its not like a whole lot of other brands which share different ATF fluid!
Old Aug 5, 2004 | 09:00 AM
Ummm.... I've talk to some mech and they say that using synthetic would help in lowering the temp down and is better than honda. Damnit I'm confuse now.
Old Aug 5, 2004 | 10:23 AM
bill-71SS's Avatar
Default Re: (accordinglyevil)
I have been a honda tech now since 1975,DO NOT use anything else. If you tech tells you it is ok to use that other ****,see if he will fix your trans when you f ck it up
Old Aug 5, 2004 | 11:30 AM
KGAccord's Avatar
Default Re: (bill-71SS)
you only need to use honda fluid in 98+ accords. in older ones you can use dexron III. dexron III is just a newer/ better dexron II.
Old Aug 5, 2004 | 11:46 AM
Luisito825's Avatar
Default Re: (KGAccord)
i used valvoline dextron on my accord and it never burnt or malfunctioned.
ManInBlack
Honda Civic (2006 - 2015)
Jul 15, 2013 03:04 PM
singher01
Jul 25, 2008 10:19 AM
innes887
22
Apr 14, 2007 05:00 PM
iNetForce
13
Feb 13, 2006 04:46 PM
Thanks knightsport!
Jun 8, 2005 09:54 AM
