car stalls after letting off throttle.
i have a 2000 civic ex with greddy turbo kit(EMANAGE). when i let off the gas it will stall. and the engine light does not come on. i had a cel which was the primary o2 sensor. but i replaced it today and it still stalls but no engine light. i thing i noticed is that the recommened spark plug gap is .044 but others in this forum gap down to .028. but i still dont think that woud cause it to stall. also i dont have the bov on my car yet. i dont drive it but would that also b a cause of stalling. i need serious help my car has been down for over a month and a half. p.s, i no emanage sucks but its all i have for now. thans in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene »</TD></TR><TR><TD CLASS="quote">This may sound stupid, but have you set the base idle on the car yet?</TD></TR></TABLE> u no i have thought of that. i put the turbo kit on myself,but i dont no where to turn thee idle up. im smart but stupid,lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene »</TD></TR><TR><TD CLASS="quote">This may sound stupid, but have you set the base idle on the car yet?</TD></TR></TABLE> actually in the 2 months ive been tryin to get help,that is the smartest anwser yet. im at work right now so i cant try it out. it all makes sense now. i didnt think that the idle changed when outting in a turbo kit. but yea i think u r right. it runs fine when givin throttle.
well there was a hose hangin down. i couldnt figure out were it went. there was no place for it to go. its above from were the coolant line is from the block to the throttle body. i blew into it and there was a line that was pulled off the throttle body,air was comin out of it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy »</TD></TR><TR><TD CLASS="quote">2000 Civic... Does this car use a MAF sensor? If so, an open-atmosphere BOV can cause the car to stall.</TD></TR></TABLE> im not sure, cuz in another thread i was askin peeps if i had to recirculate the bov back into the charge pipe
i dont no but i hooked it up to the intake anyways. i only have problems when i leave off the throttle. 1 thing i forgot to mention is that i dont have the bov on yet
I pray to god that was a typo and you meant MAP. The 2000 civic DOES NOT have a MAF sensor...
Anyway I had the same problem bro. My car would stall if I didnt igve it continuous gas. It was timing all along........I adjusted the timing and my **** drove like a champ
edit...you are using the e-manage...does that adjust timing wwith boost......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 »</TD></TR><TR><TD CLASS="quote">
edit...you are using the e-manage...does that adjust timing wwith boost......</TD></TR></TABLE> well the timing is good.and im not really sure what the hell the emanage does it seems like it does nothin at all,lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda9369 »</TD></TR><TR><TD CLASS="quote">i dont no but i hooked it up to the intake anyways. i only have problems when i leave off the throttle. 1 thing i forgot to mention is that i dont have the bov on yet</TD></TR></TABLE>
wait..hold the phone...no BOV?? Is it an internal wastegate...if not, that may be your problem!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ »</TD></TR><TR><TD CLASS="quote">
wait..hold the phone...no BOV?? Is it an internal wastegate...if not, that may be your problem! </TD></TR></TABLE> not sure. its a td04 19t turbo that came with the greddy turbo kit
Oh wow... BOV = Essential. You will accumulate excessive Exhaust Gas Reversion and not to mention extreme compressor damage due to the surge when the TB snaps shut. I'm surprised your I/C piping isn't all over the place.
With internally wastegated turbos, I heard that BOVs aren' t necessary unless you're running mad high boost. But having said that, I would definately check all of your vacuum hoses very carefully...something is definately not hooked up right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Freemantle »</TD></TR><TR><TD CLASS="quote">Oh wow... BOV = Essential. You will accumulate excessive Exhaust Gas Reversion and not to mention extreme compressor damage due to the surge when the TB snaps shut. I'm surprised your I/C piping isn't all over the place.</TD></TR></TABLE> well i havent really driven it. the guys at the wonderful greddy tech support (lmfao) said that i didnt need a bov with that kit. sounds like bs to me
uzzled: is this a vacuum line, or the intake hose...?
