y1 or ys1
Old Aug 4, 2004 | 08:12 PM
CrxEDguY's Avatar
Default y1 or ys1
ok, here is the problem. I bought the y1 tranny a few weeks ago and now i found a deal and also bought the ys1 tranny. Im not sure which one to use, both of them have lsd just wanted to have some peoples opinion on it. Eddie
Old Aug 4, 2004 | 08:15 PM
kaoss_11's Avatar
B A N N E D
Default Re: y1 or ys1 (CrxEDguY)
y1
Old Aug 4, 2004 | 08:30 PM
EL Vap133's Avatar
Any grinds in any of them?
Old Aug 4, 2004 | 08:48 PM
CrxEDguY's Avatar
Default Re: y1 or ys1 (EL Vap133)
i havent used eighther but both have fairly been used. why would you choose the y1 over the other?
Old Aug 4, 2004 | 09:01 PM
quick
I believe the Y1 is the "SiR" spec tranny. the gear ratios should be different from the YS1 if I remember correctly.
Old Aug 4, 2004 | 09:04 PM
kaoss_11's Avatar
B A N N E D
I think the y1 tranny has shorter gears.
Old Aug 4, 2004 | 09:13 PM
michael O's Avatar
Default Re: (kaoss_11)
I think the ys1 has the shortest gears. Only jdm or gsr though.
Old Aug 4, 2004 | 09:15 PM
kaoss_11's Avatar
B A N N E D
Default Re: (michaelOlson)
You may be right cant remember.
Old Aug 4, 2004 | 10:45 PM
VtecKiDD's Avatar
YS1 92-93 GSR USDM or JDM has shortest gear ratio
S1/J1 have same gearing as 96 type-R
Y1 has longer gear ratio
YS1 LS tranny has LONGEST gearing
I would choose YS1 with LSD if it is indeed a GSR trans. if it is a GSR an ypu dont want it PM me ill buy it from you. PM me
Old Aug 4, 2004 | 10:57 PM
CrxEDguY's Avatar
Default Re: (VtecKiDD)
how can you tell if the ys1 is from a gsr or the ls
Old Aug 4, 2004 | 11:00 PM
VtecKiDD's Avatar
Default Re: (CrxEDguY)
pop the case an count the teeth on the final drife in the ONLY way
Old Aug 4, 2004 | 11:58 PM
ExodusJKD's Avatar
So S1 and J1 are the same? My buddy has an XSi B16 with an S1 and mine from an XSi has a J1 and I thought J1 was shorter?
linkdeezie
Transmission & Drivetrain
18
Feb 4, 2019 07:34 AM
Roy2377
Dec 10, 2004 11:23 AM
B18C5-EH2
17
Jun 19, 2003 03:28 PM
iwouldHITit
35
May 29, 2003 09:59 AM
cursED
10
Jan 1, 2003 09:38 PM
