Milled head: throw off timing marks?
Old Aug 4, 2004 | 07:40 PM
Batoutahell's Avatar
Default Milled head: throw off timing marks?
I've spent hours trying to set the timing on my d16a6. It has a milled head (do not know the exact spec's). All parts are stock. After installing the timing belt, I set the cam gear to TDC, and then the crank to TDC. However, when I install and tension the belt, timing is thrown off what appears to be 4-6 degrees (advanced).
My last best guess is that the milled head is throwing off the timing. First, is that most likely the problem, and if so, what do I need to do to get timing set properly?
Old Aug 4, 2004 | 08:07 PM
500hpsi's Avatar
Default Re: Milled head: throw off timing marks? (Batoutahell)
When a head is milled the cam are closer to the crank, therefore, the timing will be retarded. To resolve this problem, you would have remove the head the mic it for thickness. If the thickness is below minum, a slim can be use. However, I would recommend a machine shop to perform the work.
Old Aug 4, 2004 | 08:48 PM
SJcivic's Avatar
Default Re: Milled head: throw off timing marks? (500hpsi)
Definately find out how much the head was decked... thats priority #1
rich
Old Aug 4, 2004 | 09:39 PM
h22eghatch's Avatar
Default Re: Milled head: throw off timing marks? (SJcivic)
My head on my h22 was milled 4 thousands and my timing marks aren't off. So, unless they milled your head down more than they should have I don't think thats the problem.
Old Aug 4, 2004 | 10:04 PM
Sack Master's Avatar
Default Re: Milled head: throw off timing marks? (h22eghatch)
My head is milled a lot more than that. The timing marks are off a very little bit. You are probably installing it off a tooth or are not reading the marks correctly. It should line up very close to stock.
Old Aug 5, 2004 | 08:09 PM
turbohondask's Avatar
Default Re: Milled head: throw off timing marks? (Sack Master)
move it one teeth either way depending on your timing to set it correctly,
You can correct it by using a thicker hg
Old Aug 6, 2004 | 12:47 PM
AzG35's Avatar
Default Re: Milled head: throw off timing marks? (turbohondask)
Milling will retard your cam timing, like said above. Do not adjust by moving a tooth over. You need to adjust by using an adjustable cam gear. It will move your timing marks off slightly, but not by a complete tooth.
88EDHatch
11
Feb 3, 2010 04:42 PM
rated_r
Feb 2, 2008 03:12 PM
petarr
Apr 7, 2006 10:11 PM
gATOr65
Dec 27, 2005 02:03 PM
J T*
Jul 2, 2002 04:27 PM
