Want to Buy Want to Trade/Want to Buy
WTB: 80mm Shim Set for Differential Installation
Old Aug 4, 2004 | 06:37 PM
Dogginator's Avatar
Daisy... Daisy...
Default WTB: 80mm Shim Set for Differential Installation
I'm looking to install an LSD in my GSR. I need the 80 mm shim set for the ball bearings (I switched from the tapered roller bearings). The part numbers follow:
41441-PL3-B00
41442-PL3-B00
41443-PL3-B00
41444-PL3-B00
41445-PL3-B00
41446-PL3-B00
41447-PL3-B00
41448-PL3-B00
41449-PL3-B00
41450-PL3-B00
41451-PL3-B00
41452-PL3-B00
41453-PL3-B00
41454-PL3-B00
41455-PL3-B00
41456-PL3-B00
41457-PL3-B00
41441-P21-000
41442-P21-000
41443-P21-000
Old Aug 6, 2004 | 06:57 AM
owen_the_soyboy's Avatar
Default Re: WTB: 80mm Shim Set for Differential Installation (Dogginator)
which one or ones of those do you need?
once you install the diff you will THEN measure the clearance and then see what thickness you need to buy.
Old Aug 6, 2004 | 07:23 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: WTB: 80mm Shim Set for Differential Installation (owen_the_soyboy)
I won't know which shim I need until I have the transmission disassembled. I cannot wait a week for for the specific shim that I need to arrive. I was hoping that someone had a set minus the one shim that they needed.
Old Aug 7, 2004 | 04:21 AM
people do not buy the "set"
your understanding of the scenario is a bit off.
the other option is this... if you order a thick one, chances are a machine shop could grind it down to whatever thickness you need, well, if they do that stuff in your area.
Old Aug 7, 2004 | 06:26 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owen_the_soyboy &raquo;</TD></TR><TR><TD CLASS="quote">people do not buy the "set"
the other option is this... if you order a thick one, chances are a machine shop could grind it down to whatever thickness you need, well, if they do that stuff in your area.</TD></TR></TABLE>
that would be your best option
Old Aug 8, 2004 | 08:51 AM
Big Teggie's Avatar
I would wait til you get everything measured.
Each shim is about $5-6 from the dealer
Old Aug 8, 2004 | 05:08 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: WTB: 80mm Shim Set for Differential Installation (Big Teggie)
The whole set is indeed expensive. I'm planning on buying the gamut and selling the ones that I don't need to the next guy who is going to install their own differential. I need to complete this task in a weekend.
MikicaED7
Jan 5, 2018 09:18 PM
medjosh6
Nov 8, 2008 11:55 PM
43MA
Jan 27, 2003 10:06 PM
