97 itr brake booster & master cylinder same specs as 2001?
i searched on this topic already but can't find anything. so i was wondering is the 97 brake booster & master cylinder the same size and specs as the 2001 except the wires are heading to the opposite directors? ive heard that the 97 brake booster & master cylinder is a direct fit on EG's without bending lines but the 2001 ones you need to bend the lines on the master cylinder. so all i want to know is if the 97 brake booster & master cylinder specs the same as the 2001 brake booster & master cylinder specs.
All Type R Master cylinders are be the same.When doing a MC conversion like you are doing to your civic you have to bend lines for all the ABS Integra MC's (LS,GSR,and Type R).If you use a Integra RS non-ABS MC it will be a direct bolt up.The different years have nothing to do with it.
hunan beef
May 9, 2011 03:43 PM
