my injectors arnt working WTF!!!!!!!!!!!!
i was driving my car and all of a sudden the car just stoped , no bogging or sputtering , i have spark , and fuel to the rail , but after cranking and cranking my plugs are dry . anyone have this problem before????
if you are running a resistor box, could be that, or most likely its the crank angle sensor. If the ignitor can't see that the crank is moving, then it won't fire the injectors.
im not throwing any codes except a 22 for vtec pressure switch . and i have a pressure guage on my rail and ill release the pressure , and prime it and it will go up.
how to i check the crank angle sensor?
you would have a code for the crank angle sensor, as its in the dizzy. the only quick way to test it is to throw another dizzy on it from a friend and see. could be ecu as well, but i doubt it.
