Which lower timing belt cover do I use?
I have a LS block with a Type R water pump, oil pump and belt tensioner. Which timing belt cover do I use? My LS cover won't work, thanks.
any 1996 USDM and up GSR or LS lower timing cover with work. Simply get the same timing belt cover for the same year oil pump you bought and youll be KOOL & THE GANG
errusieck
Apr 10, 2010 09:41 PM
