alinement problem EF Gurus look inside
Old Aug 4, 2004 | 10:23 AM
Boosted Chemist's Avatar
Default alinement problem EF Gurus look inside
Ok i went to get my crx alined (caster camber{i got a crossmember} and toe) they told me that my tie rods where adjusted all the way in and that the car is still toed out too far (also tried to charge me 350 bucks but i havent settled that yet) Now i have CRX Sir knuckles with new carquest/moog tie rods (outers) does the knuckles affect the toe at all? or is it the non-oem tie rod? ive never heard anything about these knuckles so i figure its the tie rods.
**** i need help
Old Aug 4, 2004 | 10:34 AM
EL Vap133's Avatar
Default Re: alinement problem EF Gurus look inside (Mad Chemist)
All you used from the SiR were the knuckles right, nothing else like LCAs or upper arms?
Old Aug 4, 2004 | 11:19 AM
Default Re: alinement problem EF Gurus look inside (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">All you used from the SiR were the knuckles right, nothing else like LCAs or upper arms? </TD></TR></TABLE>
yeah but i heard you dont need those
Old Aug 4, 2004 | 11:20 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mad Chemist &raquo;</TD></TR><TR><TD CLASS="quote">
yeah but i heard you dont need those </TD></TR></TABLE>
Don't need what?
the lca or upper control arms (sir one, the si will work)
Im wondering if hte problem lies in the moog tie rod ends
Old Aug 4, 2004 | 11:33 AM
EL Vap133's Avatar
I see, I used my stock LCAs, and upper arms, I just used the Teg knuckles and I don't have any problems.
Old Aug 4, 2004 | 11:35 AM
thats what i have but im using a SIR knuckle and my car is slammed, do u think its my tie rod ends?
do you have oem?
Old Aug 4, 2004 | 11:40 AM
EL Vap133's Avatar
Yeah, mine are OEM as of now. It could be that but I am no alignment expert so I wouldn't want to give you any bad info.
Old Aug 4, 2004 | 12:19 PM
4drEF's Avatar
Keyboard Humorist
I'm running the SiR knuckles.
Here's my install write-up
http://home.socal.rr.com/civic...x.htm
The tie rod hole in the knuckle is noticably closer to the steering rack.
Old Aug 4, 2004 | 01:54 PM
y_design's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">I see, I used my stock LCAs, and upper arms, I just used the Teg knuckles and I don't have any problems. </TD></TR></TABLE>
So what you're saying is that 90 teg knuckles would work fine in a 90 crx with stock lca and upper? It would not screw up the aligment?
I have a donor 90 rs teg that I would love to part out...
Old Aug 4, 2004 | 02:51 PM
Default Re: alinement problem EF Gurus look inside (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">I'm running the SiR knuckles.
The tie rod hole in the knuckle is noticably closer to the steering rack.</TD></TR></TABLE>
your the man i thought the after market tie rods are too long, nice
Old Aug 4, 2004 | 07:37 PM
I Have an STD's Avatar
wrenchin'
justin, i took a look at your tires today, that is the worst toe in wear i have ever seen
Brett
Old Aug 4, 2004 | 07:51 PM
ketchup's Avatar
lol that write up was yours ? nice
personally, i wouldn't use teg knuckles, i had a set and decided to go with the EX knuckles instead. i've heard the teg knuckles will fit and all but your alignment wont be right.
Old Aug 6, 2004 | 07:33 AM
ketchup's Avatar
Default Re: alinement problem EF Gurus look inside (I Have an STD)
you should have seen my tire wear, it wore down to the metal wire threads !!
Old Aug 6, 2004 | 08:09 AM
iain's Avatar
Default Re: alinement problem EF Gurus look inside (ketchup)
to use siR knuckles you nees to use the siR track rod ends also as the siR track rod ends are shorter than the ones you replaced
you don't need the upper arms or lca's
Old Aug 6, 2004 | 08:26 AM
EL Vap133's Avatar
Default Re: alinement problem EF Gurus look inside (y_design)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y_design &raquo;</TD></TR><TR><TD CLASS="quote">
I have a donor 90 rs teg that I would love to part out...</TD></TR></TABLE>
Yes, I have been using 91 Teg knuckles for about 8 months now and I have no problems so far. I just needed to get an alignment right after I got them installed.
Old Aug 6, 2004 | 08:32 AM
Footwork's Avatar
4drEF's Avatar
Keyboard Humorist
Default Re: alinement problem EF Gurus look inside (iain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iain &raquo;</TD></TR><TR><TD CLASS="quote">to use siR knuckles you nees to use the siR track rod ends also as the siR track rod ends are shorter than the ones you replaced
you don't need the upper arms or lca's</TD></TR></TABLE>
Seems like you didnt' read the whole thread.
I used all USDM parts except the knuckles.
See the previous reply I did with my install write-up.
It's a whole lot easier to just mod the tie rods than to try sourcing JDM SiR ones.
Old Aug 6, 2004 | 09:25 AM
iain's Avatar
you are correct i haven't read your write up, i was going from memory when i did mine
i'm assuming if he can get the knuckles the track rod ends shouldn't be a problem either. which is easier than modding standard ones.
Old Aug 6, 2004 | 09:27 AM
EL Vap133's Avatar
It's a whole lot easier to just mod the tie rods than to try sourcing JDM SiR ones.</TD></TR></TABLE>
A friend of mine did the same thing on his 91 hatch.
Old Aug 15, 2004 | 11:16 AM
i finally went to shorten my tie rods and thread them, the thread is 14x1.50. a die that seems to be impossible to find anywhere the place i have to order one off of is http://www.etaps.com, just a fyi for any one in the same situation
EFstyle
10
Apr 19, 2008 03:13 PM
powerpro_69
Mar 8, 2007 03:09 PM
ozrednsx
Nov 9, 2006 11:18 AM
CrazyKoreanCrx
Feb 8, 2004 12:49 PM
turborex
15
Jan 28, 2004 08:48 PM
