Rear CRX brakes question.
Old Aug 4, 2004 | 09:29 AM
ImportsCRX's Avatar
Default Rear CRX brakes question.
About 2 months ago, i was driving to hooters with a bunch of friends. I kept pumping my brakes and the next thing you know, my car shuts off and i have no brakes. I immediately start up the car and drive to the nearest gas station without brakes. When I parked the car, i noticed that the brake fluid was leaking from both the rear brake lines. For a quick fix, my friends clamped down the hose so i only use the front brakes. How much you guys think it would cost to get it fixed at a shop? or what parts will i need to fix this problem myself? i know i'm going to need rear pads because they were basically warn out.
Old Aug 4, 2004 | 09:37 AM
crx_88_si's Avatar
where is it leaking? in the middle of a hard line or on a connection somewhere?
Old Aug 4, 2004 | 09:53 AM
ImportsCRX's Avatar
Default Re: (crx_88_si)
i'm pretty sure it's leakin from the inside of the drum.
Old Aug 4, 2004 | 10:49 AM
crx_88_si's Avatar
Default Re: (ImportsCRX)
probably just bused the drum piston seal... time for a new set.
mikec35
May 25, 2014 08:31 PM
95TEG
Jun 11, 2005 07:37 AM
bseriesboosted
Dec 29, 2003 08:33 PM
sting94112
Acura TL, RL & ZDX
Nov 5, 2003 10:01 PM
