Gettin That Back Seat Outa There
If you want to keep it, just be careful, and try not to break the clips holding the seat on, or together. I did this about a year ago, and I can't remember where the locations are. Just start with the bottom (butt part) and work your way around slowly. It's actually pretty self-explanatory.
TOOLS REQUIRED:
= 10mm Socket/wrench
= Pliers
Using the pliers, remove the plastic spacing clips on each side of the seat-back pivots (1 on each side).
Once these spacers are removed, you can slide the seat-backs from side to side. Push the drivers-side seat-back towards the passenger side, and the outer pivot should come loose from the hole.
Do the same thing to the other side and remove both seat-backs with hatch carpeting attached.
To remove the bottom seat cushion, there is one 10mm bolt to the rear of the seat (where the seat-backs used to be). Once this bolt is removed, the entire bottom cushion can be flipped up towards the front of the car. The front edge of the seat-cushion is held in place by metal tabs, and can be easily lifted out at this point.
= Pliers
mmmmm no eg....so vanns last night at like 12 Ms.Seldonya called me
Basically this kid is a liar owns no eg, rotas, jdm corner lenses, no nppl, and **** of that nature
but he does own vaans ef, cleans it, puts stickers on it
why the hell do you keep typing that, I dont think anyone cares, but you. you can come over and see the lenses, you can also see my bank statement sayin "997.oo US currency : Foward : Maria F. Saldana....etc. I mean come over and ill whip both of the out.
