Transmission Questions
Old Aug 3, 2004 | 10:18 PM
slowman's Avatar
I took way too long
Default Transmission Questions
Does anyone know how many input shaft splines there are on 88,89,90,and 91 Si transmissions?
I know my 90 Si had 20 splines, and I just picked up a tranny and it had 21 splines. I believe it's 88-89 but I'm not sure. It pissed me off because I got it right up there and played with it for like 30 mins and it wouldn't go on. Then I counted and I was like oh boy this is bad.
So I'm going to order a new clutch plate and needed to know which clutch plate has 21 splines. Thanks so much!
Old Aug 4, 2004 | 12:02 AM
88CiViC_DX's Avatar
Default Re: Transmission Questions (slowman)
88 trannys have 21 splines. 89-91 have 20 splines.
Old Aug 4, 2004 | 05:41 AM
jlicrx's Avatar
you need clutch for 88 Si (200mm diameter) - you will also need 88-89 flywheel in order to use the 200mm diameter clutch - the 90-91 flywheels are for a 212mm clutch and the bolt circle for the pressure plate mounting bolts is larger on the 90-91 - 88-89 pressure plate will not bolt to 90-91 flywheel
Old Aug 9, 2004 | 08:45 PM
zccr-xsi's Avatar
Default Re: Transmission Questions (jlicrx)
not true i have a 89 dx flywhell with 91 si clutch fits good hooked to a daul cam zc
Old Aug 9, 2004 | 10:34 PM
RC_SKUBY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowman &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know how many input shaft splines there are on 88,89,90,and 91 Si transmissions?
Same thing happened to me, except it took a little longer for me to figure out, pissed me off
Super79Dave
Jan 24, 2007 03:48 PM
legacytunes
Apr 8, 2004 09:18 PM
Bailhatch
Sep 18, 2003 04:04 PM
.ShawnD.
Nov 9, 2002 08:41 AM
