B16 or B18C?
Old Aug 3, 2004 | 08:28 PM
1blownnteg's Avatar
Default B16 or B18C?
I am in the process of getting an Engine swap and need to know what the Pros and cons of the two. Is it an easy swap? Does it bolt right in or is there mods to be made?
Old Aug 3, 2004 | 09:20 PM
kid-honda's Avatar
To broad of a question bud.
Search then come back with more specific questions.
B16 is easy since its obd 0 and the b18 will require more wiring and money.
Both good choices.
Both require close to the same amount of work to install aside from some more wiring for the B18C since you need to convert to OBD 1.
Old Aug 3, 2004 | 09:26 PM
eda6's Avatar
Default Re: (kid-honda)
either motor will be nice.
i've had my b16 for almost a year w/no problems.
Eventually you'll want more.
If you want to convert to b18c5 later. get the b16
It's pretty easy if you know what you're doing
Old Aug 3, 2004 | 09:32 PM
crazyb16crx's Avatar
Default Re: (eda6 hb)
since he is in cali nomatter what engine he gets wont he have to convert the wiring. b16 to obd1 and gsr to obd2 pending on the year? unless he doesnt want to smog it
Old Aug 3, 2004 | 09:35 PM
1blownnteg's Avatar
Default Re: (crazyb16crx)
what do you mean as the wiring thing is confusing. What do I need to do to make a swap for a GSR swap or and Si swap?
Old Aug 3, 2004 | 09:39 PM
rjay8604's Avatar
well these two engines aren't good to compare, its like apples and oranges, the b16 has less displacement and therefore has less power, but the b18c also has a dual stage intake manifold and costs a lot more. of course if you could get them both for the same price i'd go for the b18c, but to tell the truth i'd get the b16 simply because its so much cheaper and only has a little less power. plus if you get a b18c with a hydro tranny you'll have more hybridization and you'll need hasports expensive hydro mount kit. get a 1200 dollar b16a and enjoy vtec. then when you get bored get a b18c bottom end and get some head work and cams etc. trust me the b16 is very fun, best bang for the buck.
Old Aug 3, 2004 | 09:42 PM
eda6's Avatar
Default Re: (rjay8604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 &raquo;</TD></TR><TR><TD CLASS="quote">well these two engines aren't good to compare, its like apples and oranges, the b16 has less displacement and therefore has less power, but the b18c also has a dual stage intake manifold and costs a lot more. of course if you could get them both for the same price i'd go for the b18c, but to tell the truth i'd get the b16 simply because its so much cheaper and only has a little less power. plus if you get a b18c with a hydro tranny you'll have more hybridization and you'll need hasports expensive hydro mount kit. get a 1200 dollar b16a and enjoy vtec. then when you get bored get a b18c bottom end and get some head work and cams etc. trust me the b16 is very fun, best bang for the buck.</TD></TR></TABLE>
yeah what this guy said or you can take it a step further and run an 85mm resleeved b18.
Old Aug 3, 2004 | 09:43 PM
Default Re: (1blownnteg)
u need to get the wire harness for the motor and then i think u might need a conversion harness bcuz ur car is obd0 and the gsr is obd2, if the gsr is 94-01. i think if u get a b16 it is obd1 to pass smog. so ya they arnt that hard i wouldnt think just lil but more money for wiring.
Old Aug 3, 2004 | 09:50 PM
1blownnteg's Avatar
do they make a wiring harness that converts an OBD0 to OBD1 or OBD2? If so is it smog legal?
Old Aug 3, 2004 | 09:54 PM
yes they do.u can find them pretty easy its just little more. i think they r like $150. and they r easy to use. just letting u know bout the smog thing. do a search on the smog things onthis site and it will help u make ur car pass. here is a link that might help https://honda-tech.com/zerothread?id=944945
Old Aug 3, 2004 | 10:07 PM
91EFHatch's Avatar
Default Re: B16 or B18C? (1blownnteg)
i love my b16 yes its does have less power and TQ but who care it was worth it to me i still had money let over you could do a gsr with a y1 trans so no need for the hydro kit
Old Aug 3, 2004 | 10:16 PM
kaoss_11's Avatar
B A N N E D
Go with the b16 and its a great way to get introduced to vtec. For 1400 youll have everything you need.
Old Aug 3, 2004 | 10:34 PM
s2k_al's Avatar
Yes they do make those type of harnesses just pm NEWMAN he's on this site i got my harness in pretty quick and they have good customer service.or you can just go to JDMSHIT.com
civichb03
Feb 25, 2009 09:08 PM
cypressink
May 18, 2006 05:46 PM
BigZ88
Feb 25, 2003 06:45 AM
91hatch_on17's
Jan 8, 2003 08:02 PM
