CTR 5 lug questions???
Old Aug 3, 2004 | 07:53 PM
BigMoneyP's Avatar
Default CTR 5 lug questions???
I just got a 5 lug ctr conversion and was wondering if I can use the stock e-brake cables that came with the rear disc for my 99 DX hatchback or do I have to use SI e-brake cables? I can also use the stock lines right? any help is appreciated.
Old Aug 3, 2004 | 09:14 PM
EricUSC's Avatar
Default Re: CTR 5 lug questions??? (BigMoneyP)
If your CTR brakes came with e-brake cables, you can use them provided they are in good condition. You may be able to modify your stock ones to work, but I'm not sure since your stock rear brakes are drums. I used the 99-00 Civic Si e-brake cables for my 5-lug conversion.
Old Aug 4, 2004 | 04:10 PM
BigMoneyP's Avatar
Default Re: CTR 5 lug questions??? (EricUSC)
Do I need anything else before I install the 5 lug? Everything off the 99 DX can be used for this conversion right?
*I will get MBC/ and proportional eventually.
Old Aug 4, 2004 | 04:14 PM
Jackson's Avatar
You will need the ctr brake lines or s/s lines from a 99-00 si. The rear drum brake lines will not work. Also, the proportioning valve is the same between si and dx. No need to change that.
Old Aug 4, 2004 | 05:30 PM
BigMoneyP's Avatar
Default Re: CTR 5 lug questions??? (Jackson)
would regular Si lines from the dealer work?
Modified by BigMoneyP at 6:43 PM 8/4/2004
Old Aug 5, 2004 | 01:01 AM
Jackson's Avatar
Yes, but stainless steal lines are only about $100. Why buy new si lines that will probably cost more?
Old Aug 5, 2004 | 04:04 PM
BigMoneyP's Avatar
okay, i called the dealer today, do I need the brake lines from the rear disk to the front as well as the lines from the brake caliper to some middle connector? if anyone has part #'s that'll be great, what company makes S/S lines as well? I will consider that also.
tunerman
Oct 15, 2014 07:11 PM
gsr1379
Mar 31, 2010 07:06 PM
reyrey2006
16
Sep 11, 2008 07:32 PM
hondacivichatch
Jan 19, 2006 03:41 PM
ki11a8ee
Jan 24, 2003 06:11 PM
