Removing oil pump and crank seal!! Stuck on!!
Old Aug 3, 2004 | 07:21 PM
NSTY Z33's Avatar
Default Removing oil pump and crank seal!! Stuck on!!
Anyways, the stuff is really stuck on strong, maybe it's the sealant??? How the .. am i to remove the oil pump and crank seal??? Help!! Thanks
Old Aug 3, 2004 | 08:32 PM
hondaguyef's Avatar
Default Re: Removing oil pump and crank seal!! Stuck on!! (JDMCRXDelSol)
Rubber mallet or a hammer and a brass punch
Old Aug 3, 2004 | 09:05 PM
Bobhas4's Avatar
YEah nothing better then a multi-directional high impact tool = BIGF'NGHAMMER !
~BH4~
Old Aug 4, 2004 | 09:02 PM
turbohondask's Avatar
Default Re: Removing oil pump and crank seal!! Stuck on!! (Bobhas4)
if it is still hard to take off it could be a bolt is still on it,
there should be a spot that can be pryed on that does not mar up the seal
Old Aug 4, 2004 | 10:55 PM
senpai's Avatar
You took off the oil pan and the oil strainer?
jonny11844
Oct 15, 2013 01:11 PM
mattbatson
Mar 30, 2009 07:23 PM
NoVALude
May 12, 2005 03:06 PM
alotawatts
Jan 13, 2005 04:32 AM
