Anyone have the Helms pages for the Timing belt procedure.
Old Aug 3, 2004 | 07:10 PM
DsITR's Avatar
Default Anyone have the Helms pages for the Timing belt procedure.
I'm looking for the pages of the helms that detail exactly what a tech would do during changing a timing belt/water pump/and seals.
The motor is a h22a4 in a 97 SH
If anyone has these It be uber-helpful I need some ammo for dealing w/the dearlership.
see my thread here for further details.
https://honda-tech.com/zerothread?id=945852
Old Aug 3, 2004 | 07:28 PM
naujcdl's Avatar
Default Re: Anyone have the Helms pages for the Timing belt procedure. (DsR)
6-12 to 6-20
Old Aug 3, 2004 | 08:04 PM
DsITR's Avatar
Default Re: Anyone have the Helms pages for the Timing belt procedure. (naujcdl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by naujcdl &raquo;</TD></TR><TR><TD CLASS="quote">6-12 to 6-20 </TD></TR></TABLE>
oh.. I mean, like scanned in .pdf format
Thanks though
...or if you could check out the procedure and see if it says to drain/change the oil. that would be super helpful!
Modified by DsR at 11:08 PM 8/3/2004
Old Aug 4, 2004 | 12:42 AM
TimeRacer's Avatar
You don't need to drain the oil unless you're considering changing the oil pump... Just buy the manual used for $30-40.
Old Aug 4, 2004 | 01:14 AM
Behan's Avatar
Default Re: Anyone have the Helms pages for the Timing belt procedure. (TimeRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TimeRacer &raquo;</TD></TR><TR><TD CLASS="quote">You don't need to drain the oil unless you're considering changing the oil pump... Just buy the manual used for $30-40. </TD></TR></TABLE>
Read the other thread, he is asking because ( basically) the dealer didn't do the timing belt job correctly and he needs info to back up his position.
Old Aug 4, 2004 | 02:27 AM
TimeRacer's Avatar
What specifically does he need to know? I skimmed the other post but I don't see anything other than yes, you loose some oil when changing out the balancer shaft seals and the front main seal. Quite possibly you lost some oil. When I had mine done by a friend's shop I was down probably around a quart or two from the bottom dot and they didn't fill it. Though I did check it due to the fact that they did not clamp down the coolant line so I went back and checked it all out. I doubt that you really have any issues as long as you didn't do it for a long period of time. Just as info... general compression for an H22A motor is 210-215. BUT Honda will not do anything until it's below 180 or so.
Old Aug 4, 2004 | 09:02 AM
DsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TimeRacer &raquo;</TD></TR><TR><TD CLASS="quote">What specifically does he need to know? I skimmed the other post but I don't see anything other than yes, you loose some oil when changing out the balancer shaft seals and the front main seal. Quite possibly you lost some oil. When I had mine done by a friend's shop I was down probably around a quart or two from the bottom dot and they didn't fill it. Though I did check it due to the fact that they did not clamp down the coolant line so I went back and checked it all out. I doubt that you really have any issues as long as you didn't do it for a long period of time. Just as info... general compression for an H22A motor is 210-215. BUT Honda will not do anything until it's below 180 or so. </TD></TR></TABLE>
sorry, my post is a bit hard to follow...
But, that is exactly what I needed to know. After talking to a friend that works @ a dealer he confirmed the same.
The thing is. I was missing 3 and 1/2 quarts. The car was barley driven maybe 2 days out of the week, a total of 20miles, and never saw anything above 5k revs. I'm pretty sure the car is fine, allthough when returning it to the dealer it began to idle funny when I started it up, but that could be any # of things.
bigbruin
Nov 5, 2007 07:42 AM
TOO MUCH TORQUE
Jan 3, 2007 10:34 PM
Intercooler
Aug 31, 2005 04:43 AM
Iomega01
Aug 2, 2005 08:12 PM
2camsaam
Jul 30, 2003 12:20 PM
