z6 head bolts
Old Aug 3, 2004 | 06:57 PM
dirtyturtle's Avatar
Default z6 head bolts
im starting to re-assemble my z6, and when installing me ARP headbolts. i noticed there are two bolts that sit higher than the rest... is this normal?
Old Aug 3, 2004 | 07:10 PM
Default Re: z6 head bolts (D16BEYOTCH!)
and when removed there ALL the same size. and no there not upside down.
Old Aug 3, 2004 | 07:55 PM
dsowers19's Avatar
umm, I dont think those are suppose to be like that. I just installed a d16z6 head and all the bolts are the same length. What model are the arp's for?
Old Aug 3, 2004 | 11:57 PM
peiku's Avatar
well when i installed mines, two were sitting higher than the others. they were the two by the distributor side. the rest were the same height. theyre holding fine at 210whp.
Old Aug 4, 2004 | 02:38 AM
menkio's Avatar
Default Re: z6 head bolts (peiku)
.... maybe you should let someone else assembly the block?
Old Aug 4, 2004 | 03:10 AM
elevtro's Avatar
Default Re: z6 head bolts (DewMota)
DewMota, man this is the second post I have seen from you this morning that gives absolutly no help to the people you are posting to. Did you wake up on the wrong side of the bed or something? Give the guy a break, he is just asking if the after market bolts are the right ones, or if they are not. AFter market items and even items from dealers can be packaged wrong at times, so ease up man. Go relax and let people who want to help fellow HTer's out help out.
D16,
Did the bolts come with instructions saying anyhting about install? If not call the company and see what they say, they might have packaged the wrong bolts or maybe they are correct. The manufacter will know for certain though.
elevtro
Old Aug 4, 2004 | 03:43 AM
TurboEH2's Avatar
Default Re: z6 head bolts (elevtro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peiku &raquo;</TD></TR><TR><TD CLASS="quote">well when i installed mines, two were sitting higher than the others. they were the two by the distributor side. the rest were the same height. theyre holding fine at 210whp.</TD></TR></TABLE>
Old Aug 4, 2004 | 03:48 AM
kKdARIAN's Avatar
Vice President/CEO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elevtro &raquo;</TD></TR><TR><TD CLASS="quote">DewMota, man this is the second post I have seen from you this morning that gives absolutly no help to the people you are posting to. Did you wake up on the wrong side of the bed or something? Give the guy a break, he is just asking if the after market bolts are the right ones, or if they are not. AFter market items and even items from dealers can be packaged wrong at times, so ease up man. Go relax and let people who want to help fellow HTer's out help out.
well put.
definatly do what elevtro suggested, call the company and find out if you don't get a definate answer here. Better safe then sorry bro'
good luck, keep us updated.
Old Aug 4, 2004 | 04:18 AM
Cyberdx16's Avatar
Default Re: z6 head bolts (kKdARIAN)
my bro had the same problem or i remember someone on h-t did but it was a while back. i think it had to do with having them up side down or sumthin. so u might wanna try to flip the 2 that stand taller
Old Aug 4, 2004 | 05:50 AM
ladysman's Avatar
You MUST make sure the longer threaded ends go into the block. This is important. You want the most threading in the block.
Also make sure you use the ARP lube included. Another important thing is to run a tap through the holes. If you do not, the studs won't be even.
Only 1 of them should be higher than the rest if I remember right (the passenger side closest to the firewall).
Old Aug 4, 2004 | 06:28 AM
Default Re: z6 head bolts (ladysman)
awesome. thanks for the help guys... im going to double check part# today, and try re-tapping those 2...
Old Aug 4, 2004 | 06:43 AM
part# is correct... 208-4301
Old Aug 4, 2004 | 10:42 AM
eddyboy's Avatar
Only one should be higher than the rest. I believe on the distrbuter side. If you look at you Head with the valve cover off, there is a raised part which the longer stud should be.
mikeyleed
Nov 6, 2013 11:53 AM
happyabortion
May 21, 2006 08:59 AM
Twisted Image
Mar 23, 2006 08:59 AM
EK_vzla
Sep 21, 2004 02:15 PM
MrTodd
Sep 5, 2002 08:21 PM
