94 civic b16 $5000 (michigan)
Old Aug 3, 2004 | 06:49 PM
HATCHMO92's Avatar
Default 94 civic b16 $5000 (michigan)
94 CIVIC B16/LSD $5000 DETROIT
CALL 248 259-3890
EMAIL HATCHMO92@HOTMAIL.COM
the body of the car has 140k on it , and the engine has been in for almost a year water pump, timing belt ,rear main seal,valve cover gasket were all changed less than 2k when the swap was put in , also a new plugs wires ,dis cap,rotor ,oil , trans fluid, fuel filter less than 2 weeks ago . It runs perfect and ive never had a problem with it at all, the trans has no grinds at all and shift's very smoothly . the clutch is almost brand new still grap's pefect. the interior is almost most perfect no burns or rips, the tires are also almost brand new all thread is there
94 honda civic
ENGINE:
jdm b-16 2nd gen
AEM short ram air intake
DC sport 4-1 header
NGK spark plug wire's
BOSCH platnuim 4 plugs
2.5 straight pipe exuast
AROSPEED bomb muffler
painted valve cover (white)
painted spark plug cover (flat blk)
TRANS:
s21 jdm
factory jdm LIMITED SLIP DIFFERNENTIAL (LSD)
ENERGY SUSPENSION shifter bushing kit
SKUNK2 short throw shifter
EXCEDY stage 1 organic racing clutch
GM syncomesh trans fluid
suspension:
ROTA subzero silver with polished lip 15x7
FALKEN ziez 205/50/15
zonikie open end lug nutz
SKUNK2 sleeve coil over's
KYB agx 4 way adjustable racing shock's
EXTERIOR:
TINTED window's 17% front 7% back
VIS carbon fiber hood , oem style
jdm ferio tail lights
jdm ferio side marker's
jdm ferio spoiler (with long L.E.D brake light)
jdm ferio door garnish
jdm ferio trunk badge's
jdm ferio sir2 badge
jdm ferio sir2 DOHC V-TEC decal
jdm ferio corner lamp's
jdm ferio emmison's tag
jdm ferio vacum diagram
jdm ferio engine vin tag
jdm ferio fuse panel cover
INTERIOR:
MUGEN steering wheel
MOMO hub
SABELT 4pt clubmen harness
ALPINE head unit
AUTOMETER dual gauge pod
honda optional audio console
jdm ferio stow pocket
jdm ferio gathers cdplayer
jdm ferio amber clock
jdm ferio amber gauge cluster
jdm ferio amber hazard switch (yes it is different in japan)
jdm ferio amber defroster switch
jdm ferio amber climate control
jdm ferio power mirror switch
jdm ferio tire pressure tag
Old Aug 3, 2004 | 09:18 PM
HATCHMO92's Avatar
ttt
Old Aug 4, 2004 | 08:23 AM
HATCHMO92's Avatar
BUMP #2
Old Aug 4, 2004 | 10:05 PM
HATCHMO92's Avatar
BUMP#3
Old Aug 5, 2004 | 08:31 AM
HATCHMO92's Avatar
BUMP#4
Old Aug 5, 2004 | 03:22 PM
HATCHMO92's Avatar
BUMP#5
Old Aug 5, 2004 | 05:50 PM
HATCHMO92's Avatar
BUMP#6
Old Aug 5, 2004 | 09:47 PM
HATCHMO92's Avatar
BUMP#7
Old Aug 6, 2004 | 07:38 AM
HATCHMO92's Avatar
BUMP#8
Old Aug 6, 2004 | 08:29 AM
THEFiJiMAN's Avatar
Default Re: (HATCHMO92)
Bump; PM...
Old Aug 6, 2004 | 07:56 PM
HATCHMO92's Avatar
BUMP#I LOST COUNT
Old Aug 6, 2004 | 08:25 PM
Mediocre Generica's Avatar
This is a very clean car, I've seen it in person, very well done.
HATCHMO92
Jul 28, 2004 12:53 PM
HATCHMO92
Jul 21, 2004 04:57 PM
HATCHMO92
Jul 16, 2004 09:53 PM
HATCHMO92
Apr 21, 2004 05:06 AM
