can u put a dohc zc head on a sohc zc block
just like the topic states can u? i need help asap please my rods are shot in my zc and i can pick up a sohc block for cheap if not does anyone have a dohc block thanks
Screw you guys, I'm... going... home.
The head bolt pattern of the JDM dohc ZC is only shared with the D16A1 from 86-89 integras and the EV#, EW#, and D15A# engines from 84-87 Civics/CRXs. All 88+ sohc d-series engines use a different head bolt pattern. If you don't believe it, compare head gaskets. So the answer is..............NO!
you can put a dohc cam head on a sohc block http://www.thezcr.com/forums/s...14474 youre welcome
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zaks90v8 »</TD></TR><TR><TD CLASS="quote">you can put a dohc cam head on a sohc block http://www.thezcr.com/forums/s...14474 youre welcome</TD></TR></TABLE>
Too much work for a DOHC head personally. I'd rather build up the SOHC.
Yes, it's possible, but most people (including myself) would argue that it's not worth the time or effort.
yeap it can be done.
All bolts will be differente, an one of the holes in the head must be moved.
It's easear to get an entire dohc block.
That thread in d-series is old has...
This reminds me the sleeved 80/81mm D16 pistons question, and 4x4 crx question....
From time to time someone goes and makes it, and the you feel like you're not the silliest person on earth.. lol!
duefuss
Jan 24, 2008 09:12 PM
