Fuel pump doesn't prime, Main relay?
Old Aug 3, 2004 | 04:53 PM
wickedEFguy's Avatar
Default Fuel pump doesn't prime, Main relay?
First my car is a 90 CRX Si, B16A swap
The other day I was driving along the road when suddenly my car just died and wouldn't start again. The fuel pump doesn't prime anymore and I get no CEL's. I'm starting to think it's either the Fuel pump or the main relay.
To start out with the obvious I've already check my fuse box under the hood and there all good, checked all connections and reseated them. If a fuse was to blow under the dash which one would it be?
Is there a way to test out the Fuel pump out?
If it is the Main relay it's located in the drivers side kick panel and it held to the body with a 10mm right?
thanx in advance
Old Aug 3, 2004 | 05:07 PM
sit220's Avatar
Default Re: Fuel pump doesn't prime, Main relay? (wickedEFguy)
https://honda-tech.com/zerothread?id=941169
Old Aug 3, 2004 | 07:07 PM
Default Re: Fuel pump doesn't prime, Main relay? (sit220)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sit220 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=941169</TD></TR></TABLE>
thanx a ton but that's only for fuel pump wiring. what else shoudl I check to determine if it's the fuel pump or the main relay?
Old Aug 3, 2004 | 07:20 PM
HatchBox's Avatar
Skoobie no more...
you can check the main relay, hold on let me get a pic..
Old Aug 3, 2004 | 07:27 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Fuel pump doesn't prime, Main relay? (HatchBox)
http://www.we-todd-did-racing....D.jpg
Old Aug 3, 2004 | 08:15 PM
Bobhas4's Avatar
My firend Angel ran into the same problem with his. Our quick fix till he feels like buying another relay. Since this perticular is Known for the retarded relay. Was to just take either a screw driver or something and smack the main relay till it clicked the fuel pump on and the car will start
~BH4~
Old Aug 4, 2004 | 08:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote"> http://www.we-todd-did-racing....D.jpg
WOW, that really helps a ton . I'll test it tonight and tell you guys what results I get
jlfrnce
Dec 10, 2009 05:48 PM
Jap_Spec_Imports
Sep 10, 2008 01:43 PM
916MINI
11
Aug 11, 2008 09:51 AM
bb4socal
Feb 11, 2006 06:22 PM
