clutch fits but pressure plate doesnt line up to flywheel? whats up?
Old Aug 3, 2004 | 04:23 PM
Gant's Avatar
Default clutch fits but pressure plate doesnt line up to flywheel? whats up?
the clutch is for a 89-91 civic came with pressure plate, could it be i have the wrong pressure plate?, trying to bolt up to a d16z6
Old Aug 3, 2004 | 04:41 PM
Gant's Avatar
Default Re: clutch fits but pressure plate doesnt line up to flywheel? whats up? (Ba4)
ttt
Old Aug 3, 2004 | 06:17 PM
88CiViC_DX's Avatar
is it for an 89 or 90-91 the clutch that is, cause they are two diff sizes. 89 is 200mm and 90-91 is 212mm. also what flywheel are you using?
Old Aug 4, 2004 | 05:06 PM
Gant's Avatar
Default Re: clutch fits but pressure plate doesnt line up to flywheel? whats up? (88CiViC_DX)
i thought all 89-91 clutch kits were the same wtf? im talkinga bout the pressure plate not the clutch
Old Aug 4, 2004 | 06:02 PM
88CiViC_DX's Avatar
hrmm.... i think an 89 is different than a 90-91 pressure plate... not too sure though.. sounds like it might just be a wrong pressure plate.
Old Aug 4, 2004 | 06:43 PM
jlicrx's Avatar
clutch and pressure plate for 89 is 200mm diameter - 90 and up are 212mm diameter - the 89 pressure plate will not bolt to 90 & up flywheel - the bolt circle for the pressure plate attaching bolts is larger diameter on 90 & up - if you have 90 or newer flywheel, you need 90 & up clutch and pressure plate - 89 won't work
AWD: Jeff
Transmission & Drivetrain
Jun 2, 2010 08:04 AM
thedudefromjerz
Aug 1, 2008 09:54 PM
DC2-JRSC'd
Jul 6, 2004 03:07 PM
Just Checking In
Mar 27, 2003 09:41 PM
