crx bushing...
Old Aug 3, 2004 | 01:17 PM
Dyn0speed's Avatar
Default crx bushing...
i want to put in new set of suspension bushings for my crx...but dont know which kind is the best and are reliable...so wat do u guys recomend? thnx.
Old Aug 3, 2004 | 01:24 PM
kid-honda's Avatar
I use energy.
Old Aug 3, 2004 | 01:29 PM
rexerk's Avatar
Default Re: crx bushing... (Dyn0speed)
polyurethane, go with no other material lol
Old Aug 3, 2004 | 01:33 PM
Dyn0speed's Avatar
Default Re: crx bushing... (ullerw)
energy and polyurethane are they the same?
Old Aug 3, 2004 | 01:36 PM
underage's Avatar
energy is a brand and polyurethane is the material that is used to make them. i'm fairly sure that energy is polyurethane.
Old Aug 3, 2004 | 01:39 PM
Dyn0speed's Avatar
Default Re: (underage)
k.lol does it really help you turn better and gives you a smoother ride with no suspension sweak. if i install it rite!
Old Aug 3, 2004 | 01:45 PM
kid-honda's Avatar
It gives you a tighter firmer ride and it may squeke a little bit but you can add zerk fittings to regrease.
Old Aug 3, 2004 | 02:28 PM
tolnep's Avatar
I looked at doing this on my 91 HF when I installed my GCs and Koni yellows. Suspension bushings were in OK shape so for now no. But I spent about 2 weeks id'ing all of the options. I found and priced all of the OEM bushings using majestic dealer internet. About 350 or so for all I think. Then I looked at Energy systems kits and finally the solid bushings. Considered all variations and would probably gone with OEM in the end because I want a firm sport ride as opposed to a dropped autocross ride with squeaks. Consensus of people who used their cars as daily drivers was go OEM. If i had decided to do the job, I was gonna buy a 20 ton press to help in the process. About 160 bucks. This after reading about a zillion posts on several forums and also talking to my local suspension shop. If I removed all parts and had a machine shop just press-in/press-out it was still a bunch of money just for the work. From what I gather, bushing replacement is about as tedious and messy as anything you can do on a CRX. Only thing harder that I've run into was replacing a complete dash with a new OEM dash in a 73 240z including the wiring harness. I think I am the only person on earth to do that horror...
Old Aug 3, 2004 | 02:35 PM
kid-honda's Avatar
Default Re: crx bushing... (tolnep)
Well ask me about bushing installs.
Its easy as hell and if you lived close I would gladly say come over and I will do it for ya Its easy and for the price you sure can feel a difference.
Tweakmeister
59
Dec 9, 2024 10:49 AM
Integra4lyfe069
31
Sep 9, 2009 06:56 PM
Chimichanga
Mar 18, 2009 07:51 PM
HybridEL
Jul 9, 2003 08:05 PM
