Skunk2 H22A Manifold...Just received the first batch...
Well we just got the first batch of these long awaited manifolds...but there is positive and some negative notes....here are some pre-warnings....
** The Skunk2 H22A Intake Manifold is for Off-Road Use only. The design elimanates the use of EGR Valve and the IAC Valve.
For applications using the stock ecu, it will be necessary to connect and remotely locate the EGR and IAC. We have included 2 IAC adaptor plates that can either be used as blockoff plates or as a remote IAC mounting kit. If the IAC and EGR valves are to be retained, we recommend that they be securely mounted. Mounting location and brackets are the responsibility of the installer.
We do not recommend installing the Skunk2 H22A intake manifold on the Prelude SH models until the solution to defeat check engine light is made available.
Skunk2 is not responsible for manifold fitment issues on transplant applications. **
I will have pictures of it up in a lil bit
Modified by PRojectSi2 at 2:31 PM 8/3/2004
naa, now i'll just bitch for a h23 manifold...... the skunk mani kinda dissapointed me to be honest.... looks very thrown together n half assed...... not sure why that is, they've had plenty of time to work on it.........
Golden EG6
Jan 31, 2007 06:28 AM
se93
Jun 3, 2002 10:47 PM
