Rear strut braces (ef civic -> ef Crx )
Old Aug 3, 2004 | 12:16 PM
Rob.'s Avatar
Default Rear strut braces (ef civic -> ef Crx )
Just wondering if a strut brace that fits a rear ef civic will fit on a crx as well.
I wanna get a front + rear bar from OMP.
I KNOW THE FRONT WILL FIT, BUT HOW ABOUT THE REAR ??
http://www.ompracing.it/barre/...a.pdf
thanks guys
Old Aug 3, 2004 | 12:23 PM
JCracer723's Avatar
Default Re: Rear strut braces (Rob.)
same ****..
Rob.'s Avatar
Default Re: Rear strut braces (JCracer723)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 &raquo;</TD></TR><TR><TD CLASS="quote">same ****.. </TD></TR></TABLE>
are you 110% sure they're the same ??????
Old Aug 3, 2004 | 12:25 PM
JCracer723's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. &raquo;</TD></TR><TR><TD CLASS="quote">are you 110% sure they're the same ??????</TD></TR></TABLE>
if u can swap the rear sway bars..
Old Aug 3, 2004 | 12:27 PM
Rob.'s Avatar
if u can swap the rear sway bars.. </TD></TR></TABLE>
I am not talking about rear sway bars..
I wanna know if the bolt pattern is the same and the length is the same for the rear strut towers on both cars......
Old Aug 3, 2004 | 12:28 PM
JCracer723's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. &raquo;</TD></TR><TR><TD CLASS="quote">I am not talking about rear sway bars..
I wanna know if the bolt pattern is the same and the length is the same for the rear strut towers on both cars...... </TD></TR></TABLE>
yeah thats wut i meant.. if u can swap sway bars. brakes.. shocks springs.. etc .. everything its the same
Old Aug 3, 2004 | 12:31 PM
Rob.'s Avatar
ok thanks...
anyone else can confirm this ?
Old Aug 3, 2004 | 12:32 PM
JCracer723's Avatar
Default Re: (Rob.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks...
anyone else can confirm this ?</TD></TR></TABLE>
lol just go to eaby and you will see that the bars for the 88-91 civic will fit on a crx.. i mean they are both civics..
the rear strut bars even fit egs
Old Aug 3, 2004 | 12:33 PM
Rob.'s Avatar
ok thanks
Old Aug 3, 2004 | 02:50 PM
4inspeed's Avatar
Default Re: (Rob.)
confirmed
Old Aug 3, 2004 | 03:40 PM
krazie1's Avatar
BANNED
Default Re: (4inspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4inspeed &raquo;</TD></TR><TR><TD CLASS="quote">confirmed </TD></TR></TABLE>
I second that motion
Old Aug 3, 2004 | 04:32 PM
EJ2-Fluffy's Avatar
:thumbsup:
Remember the 88 CRX rear suspension was a lil different from the 89-91 CRX. If it matters at all.
Old Aug 3, 2004 | 04:45 PM
kylefakesi-r's Avatar
Default Re: (CRX-Fluffy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX-Fluffy &raquo;</TD></TR><TR><TD CLASS="quote">:thumbsup:
Remember the 88 CRX rear suspension was a lil different from the 89-91 CRX. If it matters at all.</TD></TR></TABLE>
that was essentially the lower control arm and the shock assembly. the uppere mount and such is the same meaning that a upper strut tie bar will in fact bolt up correctly like it would any 89-91. the underside suspension differences have no effect on the actual chassis/shell which is the same throughout the years.
Old Aug 3, 2004 | 04:50 PM
Rob.'s Avatar
THANKS GUYS ! I ordered the bars.
Old Aug 4, 2004 | 01:39 PM
SETI20's Avatar
Default Re: (Rob.)
Front (MA1647)
Rear. (MA1648)
Sorry that I don't have a clearer pic. It's mounted directly onto the shock, and not to the chassis.
Modified by SETI20 at 11:57 PM 8/4/2004
Modified by SETI20 at 11:58 PM 8/4/2004
Old Aug 4, 2004 | 01:42 PM
4drEF's Avatar
Keyboard Humorist
Default Re: (SETI20)
What MC and booster are you running?
Old Aug 4, 2004 | 01:55 PM
SETI20's Avatar
OEM mc and booster. Brand new tho.
I have VT front suspention/brakes with accord calipers and SS brake lines. Works just fine with the OEM booster and mc.
Old Mar 31, 2005 | 06:36 PM
pinkgrease's Avatar
Hi I live in Australia and i also own a crx. I just wanted to know how much you pay'd for your's U.S. as it is a really tide vehicle. I Payed 6,568 U.S. for mine with only 76,000km (47,224 miles). It has compleatly new paint that is Imaculate. Your's also looks really good i was just curious to if or what mods it has or had when you brought it and if you lowered it your self. And correct me if i'm wrong but isn't a D16A6 a sohc?
thanks.
Old Mar 31, 2005 | 07:32 PM
GSRCRXsi's Avatar
Default Re: Rear strut braces (pinkgrease)
just a heads up the front OMP bar is very close to the stock MC. and if you have an upgraded MC like a 15/16 from a civic ex or something then it wont fit.
whiteguyndahood
Nov 25, 2006 08:01 PM
wtfda88
May 16, 2006 06:06 PM
L_K
Aug 4, 2004 12:30 PM
