Who knows there Emissions?? I failed
Old Aug 3, 2004 | 12:07 PM
rtpassini's Avatar
Default Who knows there Emissions?? I failed
well i went to emissions today with my sol. i just put an h23 in it. i dont have the egr hooked up yet. but i went for it anyways.
(idle testing)
my HC was 2000 (supposed to be 220 lol)
my CO was 6.51 (supposed to be 1.2)
i also think theres something wrong with my TPS because my idle is weird...
any help or ideas?
Old Aug 3, 2004 | 06:24 PM
taz77's Avatar
New User
Default Re: Who knows there Emissions?? I failed (rtpassini)
HOLY ****!!!
geezz... where to start... check EVERYTHING that will cause a car to run rich.
tps
map
fuel pressure
injectors
ecu
o2
ect
iat
what was your 02 readings at and C02 at?
Old Aug 3, 2004 | 07:21 PM
rtpassini's Avatar
my c02 was fine. it was at 7.6
im thinking my egr will help this a lot. there might be a leak in my header too.
map sensor is new.
injectors i would assume fine.
fuel pressure fine
ecu is fine
my o2 sensor may be fubar. who knows.
tps might also be off.
Old Aug 3, 2004 | 07:43 PM
taz77's Avatar
New User
Default Re: (rtpassini)
7.6 is terrible... it should be at least 14.5.. the higher the better. it's basically a indication of engine efficiency.. seeing as how LOW it is, i would take a look at how good your ignition system is.
how is your o2 readings? i'm betting its more than 0.5%...
as far as checking the map... what is the map voltage? your map sensor may be perfectly fine, but if u have a vacuum leak, the voltage will be high eventhough the sensor itself is fine.
Old Aug 3, 2004 | 08:09 PM
rtpassini's Avatar
they dont have a o2 reading listed. just HC, co2, and co.
what should i do about my ignition system? i JUST replaced the spark plugs...cap and rotor?
Old Aug 3, 2004 | 08:30 PM
hondaguyef's Avatar
What ECU are you running? Do you know if your cat is good? I would guess that you have a vacum leak somewhere? Hooking that EGR up will definately help!
LMK
Phil
Old Aug 3, 2004 | 08:38 PM
rtpassini's Avatar
i dont have the IAB or EGR hooked up (i dont think the IAB would effect this though) also my cat should be good. ill obviously test it out though. my ecu is either a p14 or p13 (i always forget. but its from a 94 prelude si.)
colnago
Apr 7, 2007 11:14 PM
fullraceacura
Mar 30, 2005 06:15 PM
delSolLS
Aug 5, 2004 11:10 AM
clean
Oct 8, 2001 04:20 PM
