Which DA integra front crossmember?
I'm having clearence issues with the outlet of the turbo and fitting the 92-95 fluidyne. Which front crossmember/traction bar setup do you suggest?
go to g2ic.com and search for Place Racing, or z10 crossmembers. those are aftermarket manufactured xmembers that i personally have no experience with, but i hear about em. good luck
You might want to avoid the Place Racing one, search for it on g2ic, but you should find a story about how it hangs too low and can be easily ripped off if your car is low enough.
Here is a pic of the aftermath and the thread on g2ic
http://www.g2ic.com/forums/showthread.php?t=96606
I have heard good stuff about Full-Race crossmembers as well
http://www.g2ic.com/forums/showthread.php?t=96630
Dude, click here http://www.g2ic.com sign up, and then SEARCH until your heart is content. There is a ton of info on this.
http://www.g2ic.com/forums/sho...t=z10
http://www.g2ic.com/forums/sho...ction
degradated
Jun 18, 2001 09:06 PM
