Vehicle Speed Sensor??? Help Please!
Old Aug 3, 2004 | 09:30 AM
QuarterMileMaster's Avatar
Default Vehicle Speed Sensor??? Help Please!
I have an 89 civic hatch w/a sohc zc swap. I have a crx si gauge cluster and my speedometer quit working a couple of days ago and my check engine light came on. My ecu is blinking code 17 which is the vehicle speed sensor. Which would make sense but I don't know where it is and what I need to do to fix it. Any info would be great.
Old Aug 3, 2004 | 09:58 AM
4DRmafia's Avatar
it should be mounted on the tranny
Old Aug 3, 2004 | 10:05 AM
4drEF's Avatar
Keyboard Humorist
Default Re: (SkipMic2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote">it should be mounted on the tranny </TD></TR></TABLE>
The VSS is mounted to the gauge cluster on the back of the speedo.
The tranny has a gear for the cable drive in it.
The cable drive routes to the back of the speedo/VSS.
Check to make sure the cable drive is secure in the gear drive in the tranny.
The come out often if they were uninstalled for some reason and the metal retaining clip was not installed correctly.
The cable drive would be the next culprit as they sometimes break internally.
HTH!
Old Aug 5, 2004 | 06:58 PM
Default Re: (4drEF)
Thanks for the info. I was able to get under my car today and pulled the speedo cable out of the tranny. The cable had snapped about 6 inches above it's connection w/the transmission. I think that would probably be the problem.
Old Aug 5, 2004 | 07:31 PM
streetmodified's Avatar
Default Re: (QuarterMileMaster)
while we're on this topic - i recently installed a B18 in my car with the tranny speed sensor that sends an electric signal to the guage cluster. however, i have retained the stock guage cluster which is equipped with the mechanical speedo cable.
has anyone dealt with this interface before? should i be getting the mechanical speedo gear out of my D16 for use in the B18, or should i try and get an aftermarket speed guage that can handle an electric speed signal?
thanks
Old Aug 5, 2004 | 07:36 PM
vtecn8ive's Avatar
Default Re: (streetmodified)
Use your cable speedo with your stock cluster. D-series and b-series are the same. Also since you won't be needing your electronic speedo I'll take it I need one for my 95 Integra GSR cluster in my 88 CRX std!!!!
Old Aug 5, 2004 | 07:43 PM
Default Re: (vtecn8ive)
actually - what happened was that the lip broke off the Dseries speedo gear on my old engine , so its technically stuck in there. i need to make a trip to a junkyard to get a new one (haha - well not new... just ANOTHER one
send me an email at wcs141@psu.edu about the B18 speedo gear. we'll talk business
Tampa Native
Feb 25, 2008 06:05 AM
pin0y209
10
Jan 16, 2008 07:56 AM
TMC_EF
Jul 16, 2007 10:37 PM
ugly rex
Jan 1, 2007 11:19 PM
kim_2_da_chee
11
Oct 8, 2003 09:02 AM
