afc+z6 head+ crx ecu= what wires to hook up?
Old Aug 3, 2004 | 07:32 AM
civictypenos's Avatar
Default afc+z6 head+ crx ecu= what wires to hook up?
crx si ecu,vafc has been in there for a while,i put a z6 head on the bitch.is the vtec wire the only wire i need to connect to the vafc,i dont have to mess with the pressure wire right?
Old Aug 3, 2004 | 07:34 AM
tgreaves's Avatar
Default Re: afc+z6 head+ crx ecu= what wires to hook up? (civictypenos)
Was the map wire hooked up before.. If your going to use the vafc you want to hook up the map wire and the vtec wire so you can add more fuel into the motor when you go into vtec..
Old Aug 3, 2004 | 07:35 AM
Default Re: afc+z6 head+ crx ecu= what wires to hook up? (tgreaves)
yeah,had it working fine before,with boost,now i just added the new head with veeeetec.
Old Aug 3, 2004 | 07:36 AM
tgreaves's Avatar
Oh ok.. Just hook up the vtec wire then and tune it up..
Old Aug 3, 2004 | 07:37 AM
thnx for the fast reply.
Old Aug 3, 2004 | 08:47 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictypenos &raquo;</TD></TR><TR><TD CLASS="quote">thnx for the fast reply.</TD></TR></TABLE>
Sure thing..
CrooksEK
Jul 23, 2014 11:45 AM
civic_boy23
Feb 2, 2007 07:15 PM
aces1980
Aug 1, 2004 10:05 AM
juicy.koreans.suck
Dec 25, 2001 01:54 PM
