crx hf to si swap help
Old Aug 3, 2004 | 05:13 AM
tcwcrxhf's Avatar
Default crx hf to si swap help
okay im in a bind and I dont get it.
I put a si motor in yesterday and the thing has no spark
I didnt change the vacuum thing on the firewall . But i dont think that would cause it
I checked the coil and igniter and the white and blue wire on the igniter didnt ground so im thinking a wire is shorted
If anyone has any ideas please please help
Old Aug 3, 2004 | 05:20 AM
HT Chaplain's Avatar
Loved
Default Re: crx hf to si swap help (tcwcrxhf)
did you change the computer? Could be the igniter in dist.
Old Aug 3, 2004 | 05:32 AM
tcwcrxhf's Avatar
Default Re: crx hf to si swap help (HT Chaplin)
I changed my computer but i dont understand how a dist. could go after its been ran earlier that day on my old motor
Old Aug 3, 2004 | 06:01 AM
tgreaves's Avatar
Make sure everything is plugged in.. The new ecu your running is a pm6 correct? Put the old pm8 ecu in there and see if it fires up then..
Old Aug 3, 2004 | 06:15 AM
tcwcrxhf's Avatar
Default Re: crx hf to si swap help (tgreaves)
Tried that im just not getting spark gonna try dizzy but i just dont see how a dizzy can go bad after 2 hours out of the car
Old Aug 3, 2004 | 06:50 AM
jlicrx's Avatar
did you use the HF engine harness? the Si harness will not work in the HF car - they are not interchangeable
Old Aug 3, 2004 | 06:52 AM
tcwcrxhf's Avatar
Default Re: crx hf to si swap help (jlicrx)
OH !@#$% thank you for your advice so much. I would like to ask though why aren't they compatable
Old Aug 3, 2004 | 06:56 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tcwcrxhf &raquo;</TD></TR><TR><TD CLASS="quote">OH !@#$% thank you for your advice so much. I would like to ask though why aren't they compatable</TD></TR></TABLE>
Two different vehicles for two different motors.. You always use the harness for the model of car and modify it if needed.. Write that down
Old Aug 3, 2004 | 07:03 AM
busychild's Avatar
https://honda-tech.com/zerothread?id=945557
Old Aug 3, 2004 | 07:04 AM
jlicrx's Avatar
the Si engine harness will plug into the HF chassis harness at the firewall, but most all of the wires are in different locations at each side of the connectors and some wires are in different connectors
777DYNASTY
May 1, 2010 09:44 AM
Rene M
Mar 19, 2006 01:11 PM
ek_b16
Oct 16, 2005 05:47 PM
JSPECHB
Jul 16, 2003 07:31 AM
pdiddyparsons
11
Nov 14, 2002 06:18 AM
