Rim size (how big)
Old Aug 3, 2004 | 02:26 AM
Turboteggy's Avatar
Default Rim size (how big)
At what point (if any) do you need to start doing body work to fit rims on a V6 99 Accord?
I'm picking mine up in 2 weeks, and want to know how big I can go. I'm definitely getting 18's, but debating on 19's. I will be going with a quality set of coil-overs springs/shocks combo, so they will need to fit under a max 2" drop. (likely 1.7")
Also, what tire size is reccomended for 18's?.....19's?
Thanks guys!
Old Aug 3, 2004 | 02:34 AM
2+2=5's Avatar
Default Re: Rim size (Turboteggy)
18x8 should fits well even with some drop, but i must warn you, cg3 will not even tuck the tires with a 3.5inch drop.(unlike civic/teg)
19 inch should be fine with a mild drop, I am using some 45series on my 17x7, lowered no less than 3 inch( more drops in the front), no rub on street and on track. in fact there's still like one finger gap to spare.
Modified by 2+2=5 at 2:09 AM 8/4/2004
Old Aug 3, 2004 | 07:58 AM
swift535's Avatar
for 18s, 225/40-18 is a common size. Your offset is a big deal too, usually a 42mm offset is pretty good
Old Aug 3, 2004 | 10:48 AM
Turboteggy's Avatar
Default Re: (swift535)
Only 225? I want 235 or 245 - hehehehe
Old Aug 3, 2004 | 10:57 AM
toxxin erik's Avatar
Default Re: (Turboteggy)
u should go with a 7.5 or 8 inch wide max with a 225/40 tire. 18s or 19s will fit fine.
sasjod
Sep 10, 2007 01:04 PM
Punk8oy81
Sep 10, 2007 07:14 AM
aln2590
May 2, 2007 04:10 AM
ezol
Jan 13, 2007 02:52 AM
tonezilla
Mar 6, 2006 05:06 AM
