96 civic suspension on 94 teg
Any of u guys using Integra suspension?
Im wondering if shocks from a 96 civic would fit on a 94 integra or vice versa..
I got a set of koni shocks from my old civic that i wanna put on my teg, should i have any trouble??
thx
thx
Aftermarket springs designed for the Civic are way too soft for an Integra. I wonder if you'd run into a similar problem with shocks.
Rainmaker
Rainmaker
96+ civics use different rear lower control arms, and thus the rear 96+ shocks are different from G3 integras. I believe the fork at the bottom of the shock is skinnier on the 96+ civics and will not even fit over the integra LCA.
all four springs and front shocks swap okay, no problem.
rear shocks are not a swappable item from EK civic to DC integra.
Q for you snooping lawyers of technicalities....are front shocks on hondas called struts? or is that the rears?
B_Swapped93
Oct 29, 2013 07:34 AM
speedracer209
Oct 23, 2006 03:22 PM
tuby
Sep 12, 2006 01:10 PM
eg:R
Suspension & Brakes
Jan 13, 2006 07:37 AM
