High Beam Bulb replacements for the Jdm front
Did a search nothing came up and looked under the frequently asked question so no flaming
Anybody have any idea what kind of bulbs i can get to replace the high beam bulbs on the jdm front to match the Oem HID's. Just thought i'd ask for those individuals who've swapped them. thanks in advance..
suggestions on where i can find these bulbs and which model? btw check ur paypal
Modified by Kicker773 at 11:07 PM 8/2/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swtxaznrac3r »</TD></TR><TR><TD CLASS="quote">i had sylvania silver star's in mine when i had my jdm front. it matched pretty well with the oem hid's</TD></TR></TABLE>
Ditto Silverstars. Good quality (beam pattern, color, light output [lumens], longevity [color temp & lumens consistent over time, and total bulb life]), reasonable price, and readily available.
Are you guys refering to the same Sylvania Silverstars that they sell at Wal-Mart? I heard the Silverstars were good, but after seeing them at Wal-Mart I got a little skeptical. Can anybody clarify this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .D2 »</TD></TR><TR><TD CLASS="quote">I haven't used my highbeams once since I got the jdm hid's</TD></TR></TABLE>
need them for some streets that have no lighting whatsoever, plus i can always use them to flash on coming ******** that high beam me all the time thinking my HID's are my high beems
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr »</TD></TR><TR><TD CLASS="quote">I say you get HID high beams </TD></TR></TABLE>
Seen a set om Josh(itrsport) has both HID's on his USDM front
Make sure you stay with the stock wattage! (Stamped on the housing / cover). Going higher wattage will damage the housing and/or reflactors (not 'equivalent' wattage as some are rated, but actual, e.g. 100W instead of 50W or whatever is 'stock'). Some are 50W (or whatever) and have output equivalent to a higher wattage but don't run any hotter. It's the extra heat from the higher wattage that melts and cracks the reflectors.
Yes, if you can get them at WalMart, go for it - save some bucks. WalMart just buys a ton of name brand stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ill »</TD></TR><TR><TD CLASS="quote">Make sure you stay with the stock wattage! (Stamped on the housing / cover). Going higher wattage will damage the housing and/or reflactors (not 'equivalent' wattage as some are rated, but actual, e.g. 100W instead of 50W or whatever is 'stock'). Some are 50W (or whatever) and have output equivalent to a higher wattage but don't run any hotter. It's the extra heat from the higher wattage that melts and cracks the reflectors.
Yes, if you can get them at WalMart, go for it - save some bucks. WalMart just buys a ton of name brand stuff.</TD></TR></TABLE>
good info
thanks but now does anyone know the stock wattage of the Dc2 HID headlights (equivalent to the sk2 ds2 HID's)?
good info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kicker773 »</TD></TR><TR><TD CLASS="quote">i can always use them to flash on coming ******** that high beam me all the time thinking my HID's are my high beems
Haha me too. Damn RHD beam pattern.
good info
thanks but now does anyone know the stock wattage of the Dc2 HID headlights (equivalent to the sk2 ds2 HID's)?</TD></TR></TABLE>
It's stamped on the housing or the bulb cover. Do I have to go look at mine?
good info
thanks but now does anyone know the stock wattage of the Dc2 HID headlights (equivalent to the sk2 ds2 HID's)?</TD></TR></TABLE>It's stamped on the housing or the bulb cover. Do I have to go look at mine?
It's stamped on the housing or the bulb cover. Do I have to go look at mine?</TD></TR></TABLE>
yes please
yes please
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
HID - 35 watts
OEM halogen - 55 watts
Remember the whole Fog light issue with the yellow lense breaking off? Its cause some of those idiots used some crazy wattage PIAA bulb that wasn't needed and the temp. in the housing got so hot, i guess the glue got weak and the lense broke off completely. There's no need to check the wattage, HID bulbs use the same amount of wattage because the Ballast acts somewhat like an Amp for the bulbs. Thats why you get the more intense light but with less wattage.
All HID bulbs are the same in wattage, its just the burning temperature (Kelvin ie 6,000k) because the Ballast require only 35 watts.
Get the SilverStars, i had em on mine. I never had a problem with it. You don't need SUPER EXPENSIVE high beam bulbs, they're high beams, hahaha. You have the HID's.
I only used my high beams once in the R, just once. I think that was to flash a CW R i saw going the other way down I-355. He flashed, i flashed. I use em to say "Hi" . haha
