PG7 ZC questions'
Old Aug 2, 2004 | 06:26 PM
vmm's Avatar
vmm
Default PG7 ZC questions'
ok im wondering.... wat year is these 2 Pg7's ecu from?88-89? and are ne of them manual transmission? needing it for my ZC.
37820-PG7-A022 and the other one has 37820-PG7-A040
Old Aug 2, 2004 | 06:35 PM
Nerologic's Avatar
all pg7's work..minus the ones that have a big X indented on the casing of the ecu...those do NOT work....
Old Aug 2, 2004 | 06:38 PM
vmm's Avatar
vmm
Default Re: (Nerologic)
so , an automatic pg7, will work the same in my manual as the manual pg7? same gains?
Old Aug 2, 2004 | 07:31 PM
T-Mo's Avatar
NOOO, only the manual one will work. The auto ones will either a) not start the car or b)give you a check engine light.
The thing about it is that both numbers that you posted seem to be from a 5speed.
Also like said above. Big "X" on the top are from a 86/87.
Old Aug 2, 2004 | 07:53 PM
jlicrx's Avatar
Default Re: (T-Mo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-Mo &raquo;</TD></TR><TR><TD CLASS="quote">
Also like said above. Big "X" on the top are from a 86/87. </TD></TR></TABLE>
Correct!! the 88-89 manual transmission PG7's are all A0## - the automatics are all A1##
Old Aug 2, 2004 | 08:19 PM
Nerologic's Avatar
Default Re: (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-Mo &raquo;</TD></TR><TR><TD CLASS="quote">NOOO, only the manual one will work. The auto ones will either a) not start the car or b)give you a check engine light.
oh yeah that too...
vmm
14
Sep 24, 2004 10:23 PM
DOHC_EF
May 22, 2004 09:54 AM
Hcivic88
Feb 27, 2003 08:49 PM
blackEF
Nov 4, 2002 03:00 PM
