SOCAL 91 CRX Si SKUNK2 GS-R
Far sale is a B18C1 w/or with out the tranny im okay with with that... its a cable tranny..
Head: Skunk2 stage 2 cams, HKS cam gears, (Skunk2)Titanium retainers, (Skunk2) springs, Type-R valves, Milled 50 thousandiths w/middle layer of head gasket removed, AEM fuel rail w/regulator, also with an Skunk2 IM w/ type-r throttle body..
Block:completly stock...
Clutch: BRAND NEW ACT Stage 2 Clutch
Tranny: new throw out bearing, new arm
the block has maybe 90,XXX miles and the head has about 2,000 before the upgrade.... with this setup it was never put back into my CRX which i am also selling..
1991 CRX Si (RED)
*94 Integra dash with shift console and arm rest
*special edition rimes with 50 series tires
*totiko coil overs
*no name struts and tie bars
*has all interior besides dash.. also various plastics are missing in the back... has cut door panels for the dash... needs wiring for the cluster (fix most of it).
*All wired up for VTEC
PM me for any questions
just updatting this... selling for 5000 firm dont want this **** anymore please take it away from me...i will even deliver it locally... also the car does not run due to someone improperly adjusting the valve clearance... checked all cylinders. Seems to be only #1 cylinder with a bent valve (holding compression at 160) but, on 2, 3, 4 its holding at 210.. the car will be sold non-opt
if there is someone that just wants to buy the motor.. and then someone wants the shell... i can seperate them...
Modified by 909rex at 6:17 PM 8/2/2004
1991 CRX Si (RED)
*totiko coil overs
still up for grabs... the head im selling for 700 damage is the valves on #1
with the head it will come with the S2 IM (one of the studs is fucked), type-R TB, and of course the head (ITR Cams, Skunk2 springs, Portflow retainers, type-r valves, and is milled 50 thousands).. and the tranny has a grind in 3rd just make an offer... very reasonable..
Bigplans06
Jan 30, 2005 04:37 PM
909rex
Aug 11, 2004 01:41 PM
