not ur typical turbo question.... i think
just wondering if its a bad idea to turbo a 6th gen accord w/ about 40000 miles or should i weight till im in like the 65k range before i overwork the engine
well the less miles the better the condition the internals are in! so turbo away! you may still want to do a compression check to make sure all is good, but it sounds to be you should be ok. granted you do the right setup, etc....
aight cool, for some reason i thought that turboing would be better on the semi-high side for mileage so that that way if turbo kills ur car it wont kill it when it still has low mileage, ah whatever, thanks again
