side air vent shift light
Old Aug 2, 2004 | 03:16 PM
95lsvteg's Avatar
Default side air vent shift light
just wondering if you think it's necessary to block off the vent before i hide the shift light in it. if so what would work. thanks.
Old Aug 2, 2004 | 03:26 PM
King_j's Avatar
Default Re: side air vent shift light (95lsvteg)
use the stock tach
Old Aug 2, 2004 | 04:17 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lsvteg &raquo;</TD></TR><TR><TD CLASS="quote">just wondering if you think it's necessary to block off the vent before i hide the shift light in it. if so what would work. thanks.</TD></TR></TABLE>
I doubt its necessary, unless you think the moving air and/or hot/cold air from heater/AC will effect it. I would think most electronics can handle the temperature changes, just make sure its sealed (the light itself, not the vent) up so the AC won't cause condensation and short something out.
Old Aug 2, 2004 | 05:13 PM
95lsvteg's Avatar
Default Re: side air vent shift light (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">
I doubt its necessary, unless you think the moving air and/or hot/cold air from heater/AC will effect it. I would think most electronics can handle the temperature changes, just make sure its sealed (the light itself, not the vent) up so the AC won't cause condensation and short something out.</TD></TR></TABLE>
no ac either
elpiar
Sep 7, 2005 08:54 PM
TedR719
Jun 7, 2004 11:58 AM
garrybloom
Apr 24, 2003 10:41 PM
00b18b
Dec 14, 2001 01:55 PM
