I need a wiring harness for a OBDI 96 vtec prelude
would anyone know where i could get and how much for an uncut/unspliced - easy to work with- wiring harness for my prelude?
it's an OBDI engine. I have the conversion harness already. the problem is my wiring harness is all cut up and i have sensors that are not hooked up to the harness like for one, my vtec solenoid is not hooked up b/c i don't have a sensor for it on my harness. the harness came with my engine but it was cut
If you have a 96 prelude your car is OBD2, you can try to find a wiring harness at a junkyard or on ebay.
However you need to search to find out what wiring harness will work best. There should be alot of info in the archives about OBD1 engines in OBD2 cars.
Good Luck
Good Luck
you're confused you have a 96 but that doesn't mean anything now that you have an OBDI motor...you need a complete 93-95 OBDI VTEC harness if you want a simple setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv »</TD></TR><TR><TD CLASS="quote">you're confused you have a 96 but that doesn't mean anything now that you have an OBDI motor...you need a complete 93-95 OBDI VTEC harness if you want a simple setup</TD></TR></TABLE>
yea, thats what I was tryin to say..
OBDI good
OBDII BAD
OBDI good
OBDII BAD
