crx problem...not starting
Old Aug 2, 2004 | 10:20 AM
hybridracer504's Avatar
Default crx problem...not starting
ok here's the problem...my friend brought his car to a mechanic to drop in a stock d16a6 motor from another crx into his....everything is wired up but it wont start....it will turn over but no spark...there is also an extra connector on the shock tower...its four wires...2 black and yellow wires, 1 red and 1 green .....im not sure if thats a important connector or not....we also put in a new distributor....any help will do...thanks
Old Aug 2, 2004 | 10:30 AM
crown14's Avatar
Default Re: crx problem...not starting (hybridracer504)
CHECK THE FUSES
Old Aug 2, 2004 | 01:10 PM
Default Re: crx problem...not starting (crown14)
which fuses...the ones in the engine bay...if so...i checked it already and its fine
Old Aug 3, 2004 | 09:21 AM
help
Old Aug 3, 2004 | 09:27 AM
BioXide02's Avatar
Soo.. if you paid someone to put in the motor.. shouldnt that person be able to fix it for you??
Old Aug 4, 2004 | 03:58 PM
Default Re: crx problem...not starting (BioXide02)
well he couldnt fix.....he said it was an electrical problem and he couldnt do it...
Old Aug 4, 2004 | 06:33 PM
BoRiCuA's Avatar
so what you have is a new dizzy with no spark?
Old Aug 4, 2004 | 06:34 PM
Ajax's Avatar
Well, I sure as hell hope he took some money off if hes a mechanic and he can't fix it...
Old Aug 4, 2004 | 06:39 PM
Jacob.'s Avatar
Default Re: crx problem...not starting (Ajax)
You need to elaborate on the problem more, it could just be somthing stupid like a blown fuse or two, the firewire may be wired wrong, plugs may be bad, hell, it might even be your battery!!
Old Aug 4, 2004 | 06:40 PM
Jacob.'s Avatar
Default Re: crx problem...not starting (Jacob.)
As a matter of fact, from what I just re-read... It's probably the fire wire.
Old Aug 4, 2004 | 07:41 PM
which one is the fire wire?...can yall guys give me a picture of wut yall talkin bout also...thanks
Old Aug 4, 2004 | 07:53 PM
Redline130's Avatar
Somethings you should check:
1)Grounds-make sure that they are all nice and secure, especially the one on the thermostat.
2)Sparkplug wires-are they in the right firing order? good condition?
3)Sparkplugs-condition? Need to be changed?
4)Distributor-Connectors plugged in? Timing?
Was the car previously a DPFI model (DX)?
Old Aug 4, 2004 | 08:00 PM
Dyn0speed's Avatar
Default Re: crx problem...not starting (Redline130)
get a wiring diagram...ignition system circuit
akinas-crx
Nov 2, 2010 12:53 PM
Channooo
Sep 16, 2009 11:01 AM
YumaCityAz
Aug 19, 2009 10:15 PM
scottmog
May 31, 2008 01:11 PM
