Troubleshoot: Ticking noise at idle
like the topic says when i start up my car i get this ticking noise from my car it isnt real loud but loud enough to hear it from 10 feet away, anybody know what it could be, anyone ever have this problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pwrd by HONDA R »</TD></TR><TR><TD CLASS="quote">like the topic says when i start up my car i get this ticking noise from my car it isnt real loud but loud enough to hear it from 10 feet away, anybody know what it could be, anyone ever have this problem?</TD></TR></TABLE>
hows your oil level? how long since last valve adjustment. is your car stock? does this go on during warmup or at all times?
give more details.
give more details.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">hows your oil level? </TD></TR></TABLE>
#1 thing to check
#1 thing to check
my oil is fine, this has been going on for some time now and i heard it might be my valves but never looked into it. it does it at all times jus not at warmup but it loud during warmup becuz of the rpms are so low. my motor is stock except for some cam gears and headers but the interals are all stock
Like Zyg stated, get valve adjustement done.. should be done every 15k miles.. look under f.a.q. for maintanance.. your car will not be in top shape unless you do all of these.
my check engine light has started blinking too, it has already been on becuz of my o2 sensor but it never blinked jus a steady light but i think im going to go get a valve adjusment today or tomorrow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pwrd by HONDA R »</TD></TR><TR><TD CLASS="quote">my check engine light has started blinking too, it has already been on becuz of my o2 sensor but it never blinked jus a steady light but i think im going to go get a valve adjusment today or tomorrow</TD></TR></TABLE>
check the code again, if its more than one code, it will flash both.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">Like Zyg stated, get valve adjustement done.. should be done every 15k miles.. look under f.a.q. for maintanance.. your car will not be in top shape unless you do all of these.</TD></TR></TABLE>
you'd have to be beating it pretty hard to need it every 15k.. not even the dealer tries to screw you for that(unlike the whole 3k miles oil change thing)..
I had the same thing, feel you spark plug wires and see if you can feel the clicking there. If so, change your plugs. one may just need to be tightened, but i would change them anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pwrd by HONDA R »</TD></TR><TR><TD CLASS="quote">can anyone give me a website for the check engine light codes i got a 67 which is the 02 sensor i think and then i got a 72 and a 73</TD></TR></TABLE>
If your plugs are tight and gapped properly, I suggest that you perform a compression check on your engine. Bent valves will cause misfiring. Does your car idle roughly?
i'd try to reset ECU and see if misfire code comes back on - your car should idle weird if it was misfiring as far as know.. check spark plug gap - are you using stock spark plugs? then check/replace spark plug wires - theres a tool to test it.
muhaMan
May 14, 2007 07:07 PM
jovial111
May 7, 2003 12:36 PM
