woke up to a puddle of OIL
Hey guys, I woke up to a tiny puddle of oil the size of CD... I looked on other spots where i usualy park and I noticed the CD size spots in 3 or 4 different places where I leave my car overnight. So i looked underneath my car and I saw a oil leak from my manual tranny. A tiny drop hanging in the middle section. Most likely its my axle leaking. So I would be looking into getting it fixed before all my oil leaks out. How much does it usually run to fix it? I know the seals themselves are only a copla dollars but what about labor? What would i be looking at? Thanks.
I'm leaking oil out of transmission. Cus thats what i have in it. A regular 10W 30 oil. I know honda recommends something else but the shop that did my auto to manual transmission swap said its OK to use 10w30 in Honda Manual trannies. So I need help figuring out where exactly is the oil leaking from... O ring on the tranny, seals, etc....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr »</TD></TR><TR><TD CLASS="quote">You're using 10w30 in your tranny??
the shop that did my h22 swap put that in my tranny and i didnt know til a week later and i started grinding gears....called him up and asked what fluid was put in, he said reg 10w30...changed it out to syncromesh immediately....
and as for the leak, i had my main seal in the tranny go, when i replaced my clutch they took of the tranny and there was oil all over the clutch/flywheel
gooberwolf
Dec 24, 2008 08:43 AM
Jason84
Acura TL, RL & ZDX
Mar 15, 2006 11:22 AM
