spun bearings
Old Aug 2, 2004 | 04:19 AM
svmnredracr's Avatar
Default spun bearings
What causes this to happen? On a fullt built motor, I dont assume this should happen. But it did, just wanna find out if its an clearence issue or motor not balanced correctly when being built or what??? Any inputs!
Old Aug 2, 2004 | 09:16 AM
tgreaves's Avatar
Default Re: spun bearings (svmnredracr)
Unbalanced bottom end, lack of oil, heat, clearances too tight.. I can also see a case where a screwed up oil pump gear can throw the balance off and do this.. What bearing did you have that spun? Was it a main or a rod bearing?
Old Aug 2, 2004 | 10:27 AM
Default Re: spun bearings (tgreaves)
Rod bearing on #2, b18c block with eagle rods
Old Aug 2, 2004 | 10:44 AM
tgreaves's Avatar
What was the clearance of the bearing?
Old Aug 2, 2004 | 10:52 AM
Motor was built by someone else, never checked it!! Should of but why.....made awesome numbers.. but the spun bearing is just something that I want to know what causes it. I'm pretty sure it was in spec, was dynoed for a period of time.
Old Aug 2, 2004 | 02:26 PM
Kwuaymaikrup's Avatar
When I spun a bearing it was due to a rod bolt stretching.
Old Aug 2, 2004 | 02:57 PM
StyleTEG's Avatar
On a properly built engine, if you spun a bearing chances are its due to oil starvation.
Old Aug 2, 2004 | 06:59 PM
Default Re: spun bearings (StyleTEG)
Thanks for all the inputs. What can you do but keep building them.
SurferDude905
Jun 29, 2009 04:30 AM
pkolaboy
Jan 9, 2008 08:50 PM
Killersohc
Nov 22, 2005 06:31 PM
Unsivil_audio
Jan 19, 2005 11:23 AM
hybrid901
Mar 17, 2003 11:43 AM
