1993 Accord SE Coupe - Leaky Trunk
Old Aug 2, 2004 | 03:57 AM
chaseengineer's Avatar
Default 1993 Accord SE Coupe - Leaky Trunk
I recently purchased a nice 1993 Accord SE Coupe.
We had a very heavy rain recently and I found a lot of water in the trunk on each side, especially the left side.
I read a discussion that indicated that the water usually comes in through the rear tail lights.
Anybody with comments on this????
Old Aug 2, 2004 | 07:23 AM
slyman's Avatar
Default Re: 1993 Accord SE Coupe - Leaky Trunk (chaseengineer)
Yeah it would most likely be either from the tail lights or the accord cancer (rust) site. If it at the tail lights put some sealant around them. If it is at the wheel well... fix the rust with some bondo and it will stop leaking. To check your rust spot, pull back the sides of the trunk and take a peak at the weld along the bottom near the wheel well.
Old Aug 4, 2004 | 06:03 PM
theotherone's Avatar
Default Re: 1993 Accord SE Coupe - Leaky Trunk (slyman)
I'd silicone the taillights if I were you. There was also a small spot on my 91 lx that leaked right below the taillight, where the factory sealant was leaking.
hondaman1992
Nov 30, 2011 06:08 PM
Wiggum84
Apr 26, 2009 06:01 PM
Ploeg8393
Nov 4, 2008 09:04 PM
van shizzle
Mar 14, 2007 03:27 PM
