93 dx accord advice needed
Old Aug 1, 2004 | 11:01 PM
slow_yota's Avatar
Default 93 dx accord advice needed
i have a 93 dx and was wondering about somthing..to bump it from a 125 hp-140 hp like the ex's, do i just have to swap out the heads or are the cams dif too?
is port & polish/angle job worth it on stock ex heads?
id like to hit 180 n/a hp on bolt ons (i/h/e & under drive pulleys) and maybe a lil internal work
(heads swap,cam & higher comp. pistons)
too high of a goal..? or
Old Aug 2, 2004 | 12:42 AM
y0whuddupb's Avatar
Default Re: 93 dx accord advice needed (slow_yota)
nOt worth it. just drop an H22 in that sucker! then you'll have 160-170 WHP to play with!
Old Aug 2, 2004 | 08:09 AM
slow_yota's Avatar
Default Re: 93 dx accord advice needed (BuRRR)
what car did the h22 come out of?..whats the capibilities (sp) with bolts on and minor internal work on that swap?
Old Aug 2, 2004 | 08:32 AM
Papichulo1767's Avatar
it comes out of the prelude
check this site out http://www.jspecautosports.com/jas/html/index.html
Old Aug 2, 2004 | 09:01 PM
slow_yota's Avatar
Default Re: 93 dx accord advice needed (Papichulo1767)
is it not possible to bolt on the h22 heads or somthing even
newer like the b18 or k20?
Old Aug 2, 2004 | 10:00 PM
david90's Avatar
just buy an sc2000.
Old Aug 3, 2004 | 01:04 AM
2+2=5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_yota &raquo;</TD></TR><TR><TD CLASS="quote">is it not possible to bolt on the h22 heads or somthing even
newer like the b18 or k20? </TD></TR></TABLE>
none, and there's no sc2000
Old Aug 3, 2004 | 08:45 AM
slow_yota's Avatar
Default Re: 93 dx accord advice needed (2+2=5)
maybe he means s2000..and i just bought a new car so thats out of the picture..thanks anyways, back to main q?..f22/ex heads/p & p..worth the swap or not?..more than one responce plz!
Old Aug 3, 2004 | 09:11 AM
crafty's Avatar
I would say keep the F22 if you plan to boost it
Otherwise if you want to stay N/A you are far better off going with the H22
Old Aug 3, 2004 | 04:30 PM
slow_yota's Avatar
Default Re: 93 dx accord advice needed (crafty)
if i could get the hp i would rather n/a but if i had i would put a couple psi on it.
is there no after market head for the f22..ive already dropped around $900.00 in the f22 so id like to keep it since i wont get that back out of it.
*i like the powerband way more on the f22 than the h22.
=h22-non vtec..havent droven the vtec h22
TriiiME3
Jan 19, 2010 08:33 AM
93accdcivickla
Nov 1, 2009 01:27 PM
GSREXMan
Mid-Atlantic (Sales)
Aug 7, 2009 05:38 AM
xcivichatch90x
Mar 27, 2005 11:32 PM
kyk007
Jan 22, 2002 08:40 PM
