47CC Pocket Bike $275 in SoCAL
Old Aug 1, 2004 | 09:46 PM
sinfultrends's Avatar
Default 47CC Pocket Bike $275 in SoCAL
Much quicker than its 49CC brother. The lighter chassis and smaller frame makes this bike built for speed. The manual start system eliminates the need for a heavy battery. Cross drilled disc brakes insure quick stops for top speeds. Please ride with a helmet at all times. Be sure to check your local laws for legality of this item in your area.
If interested please call 626 549 2805
Thank you and good luck and safe riding!
Specifications
Engine Type Gas Powered Air cooled 2 stroke Engine 47 CC
Cooling System Air Cooled
Fuel Type 25 gasoline : 1 oil
Fuel Capacity 0.5 Gallons
Exhaust System Single tip straight pipe
Fuel Efficiency Aprrox 65 MPG
Drive System Chain driven
Drive train Rear Wheel Drive
Braking Front & Rear cross drilled disc brakes
Braking System Steel cables with stiff rubber pads
Suspension N/A
Steering Adjustable handle bars with rubber grip for maximum comfort
Wheels 10" Aluminum Alloy Wheels
Tires 10" Tubeless Racing slicks
Ignition & Start Manual Pull Start ( no batteries needed )
Frame Steel
Body Panels FRP Fiber Glass
Max Load 300 lbs
Max Speed 40 MPH +
Package Contents 1. 47CC pocket bike
1. fuel and oil mixture bottle
1. bike stand
1. tool set for maintenance
1. page of decals for extra flare and style
Old Aug 4, 2004 | 12:25 PM
Default Re: 47CC Pocket Bike $275 in SoCAL (sinfultrends)
still have it
Nikos
Honda Motorcycles
Aug 31, 2011 01:19 PM
sup gurl
Honda Motorcycles
18
Sep 15, 2005 11:57 AM
Bruce Leeroy
Aug 3, 2004 07:21 AM
Eathen415
Honda Motorcycles
13
Jul 30, 2004 06:17 AM
B16aef9
Mar 12, 2004 06:27 AM
